M5od Fluid
Old Jan 24, 2008 | 11:47 PM
bumper.45acp's Avatar
bumper.45acp
M5od Fluid
I Have Been Working On My 89 F1504x4 For A While And Have About Everything Fixed But When I Checked The Trans Fluid It Had Gear Oil In It And Not Atf I Have No Clue How Long Its Been In There, How Much Damage Will This Cause? It Shifts Fine But There Is A Small Knock In It, That Might Be Throwout Bearing Not Sure.
Old Jan 25, 2008 | 12:04 AM
95F350XL's Avatar
95F350XL
You can use either atf, or gear oil. I believe ford used atf from factory. Some shop could have switched to gear oil to cover up a sound. That knock your talking about, does it make the sound when your foot has the clutch pressed, or depressed. When its pressed thats the throwout bearing. If its when its released then its the pilot. Unless its the trans its self.
Old Jan 25, 2008 | 02:10 PM
Dean88's Avatar
Dean88
Gear oil will kill an M50D. Small amounts can be used to thicken up ATF, but if it is 100% gear oil, the oil slingers in the tranny don't lube properly.
Old Jan 26, 2008 | 07:33 PM
bumper.45acp
the knocking sound is when the clutch is out, like a throwout bearing, but also sometimes when in gear and driving but not always. well how much fluid does hold.
Old Jan 26, 2008 | 07:56 PM
95F350XL's Avatar
95F350XL
Usually 2-4 quarts.
