aod trouble
Old Jan 24, 2008 | 06:36 PM
njtinman2's Avatar
njtinman2
aod trouble
ok here goes 89 f150 4x4 302 aod trans rebuilt the trans with tci kit and did the trans scat shift kit and now only have 1st and reverse any ideas
Old Jan 24, 2008 | 06:57 PM
fordfaninIL.'s Avatar
fordfaninIL.
Make sure that the throttle pressure cable is hooked up at the tranny and the engine. If it is, it may just need to be adjusted.
Old Jan 24, 2008 | 07:04 PM
njtinman2's Avatar
njtinman2
already did the tx cable adjustment
Old Jan 29, 2008 | 03:22 PM
njtinman2's Avatar
njtinman2
i droped the pan and took the valvebody a part i had the 2 releif valves in upsidedown but there was some glitter in fluid put vb back in still only 1st and rev can it be the vb has anyone used the tci trans scat kit and did it work
Old Jan 29, 2008 | 03:51 PM
Clubwagon's Avatar
Clubwagon
There is no telling what the problem is. Glitter in the pan is probably bushings and alunimum and if that is right after a rebuild, it sounds like something is wrong and chewing itself up.
Steve
'95 Clubwagon XLT
Old Jan 30, 2008 | 09:58 AM
blue beast's Avatar
blue beast
http://www.lincolnsonline.com/tech/00080.html http://www.becontrols.com/tech/ch3aodeupgrade.htm
