engine mounts
Old Jan 24, 2008 | 05:22 PM
minkbigbird's Avatar
minkbigbird
engine mounts
G'Day. What a great site. Can anyone out there help with a supplier for engine and cab mounts for a f600 mine are shot, and I live on the wrong side of the creek, Australia. hope someone can help.
Old Jan 24, 2008 | 11:34 PM
minkbigbird
engine mounts
I guess it would help if I gave more details, 292. 1964 Heavy duty. 5 speed box. Ill try agian. Brian.
Old Jan 25, 2008 | 01:23 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
Engine Mounts ~ 1964 F600 292 H/D
C3TZ6038C = Rubber Mount-Front Upper *
C1TT6A061C = Rubber Insulator-Front Lower
C3TZ603eightD Rubber Mount-Rear Upper * (a smilie code won't allow me to type 6038, then the D without making a face...as you can see:
C1TT6A061C = Rubber Insulator-Rear Lower (same as front lower)
The 2 insulators and the rear mount are the same parts as used on various locations on:
1961/64 292 F100/250 4WD's & 1961/64 292 F350's.
AND...
1961/64 F100/250 2WD's / 1961/64 F350's / all with a 223 or 262 I-6.
* FTE sponsor GREEN SALES has these parts in stock / They didn't show the insulators, but if you contact them, they might have them under another (non Ford) part number / Their link on this page...or: 513-731-3304
Cab Mounts
Even though the cabs are essentially the same as F100/350's and those cab rubber mounts have been reproduced..
The parts catalog says for 1961/64 F500/750 - "Improvise from tire carcass."
The cab (if F100/350's will work) mounts are available from several FTE sponsors.
Look on this page for links to the following:
BLUE OVAL TRUCK PARTS / MAR-K / AUTO-KRAFTERS / NATIONAL PARTS DEPOT / MAC'S ANTIQUE AUTO PARTS / Free online catalogs, free printed catalogs for the asking.
btw: The 1964/72 Ford Truck Parts Catalog is available on a CD from hipoparts.com / also on ebay - a WORTHWHILE investment for less than $25.00.
Old Jan 25, 2008 | 06:04 AM
minkbigbird
Thanks for the information. It would appear to me that the smaller f100 to 350 used a smaller mount.when I checked them here in OZ on ones imported from the U.S.A.they have a smaller dia bolt, the f600 uses a 1/2" bolt and the step on the lower mount is about 1/4" in dia.to small on the f100 which allows the ears on side of the bell housing to move around to much, though the overall height is about the same. the dia. of the f600 is a lot bigger also than the f100-350.have you ever seen an f600 engine mount? Cheers Brian.
Old Jan 25, 2008 | 10:37 AM
NumberDummy
According to the parts catalog, the engine mounts are the same.
There's more than one type used on other applications...what you saw "Down Under" may not have matched these.
Green Sales has the mounts...I suggest you contact them.
Those are the actual Ford part numbers I typed.
And, yes..I have seen (and sold) these mounts...but it's been a while since that occured..
Old Jan 25, 2008 | 02:21 PM
minkbigbird
Thanks for taking the time to help out. I will contact green sales and see what happens. Brian.
