Crankcase Ventilation Rerouting Help
Old Jan 24, 2008 | 05:18 PM
grudgeracer's Avatar
grudgeracer
I was wanting to do this while I had truck apart. Does anyone make a kit for this or is it all fab? I know there has been some issues of plumbing into the exhaust. What is the best way from experience to do this? I seen the thread on it, but would like some opinions. Thanx
Old Jan 24, 2008 | 05:56 PM
npccpartsman's Avatar
npccpartsman
Get a length of black 1" heater hose and run it to past the back of the cab down the frame rail and just tie it off.
Old Jan 24, 2008 | 06:25 PM
drakul20us's Avatar
drakul20us
I agree with npccpartsman, just run a length of hose all the way down the back, you can crossover to the exhaust side for aesthetic reasons if you want. I havent done mine yet, too bloody cold, but I'm going to use a 1" reinforced nylon tubing from home depot with a makeshift pvc trap.
Old Jan 24, 2008 | 07:09 PM
4x4Mark's Avatar
4x4Mark
I tried it on mine for a bit. At first it was fine, but I got tired of smelling it - even slightly - at idle, and my bell housing lubricant increased (RMS leak). All I can deduce is the motor needs a bit of assistance from the intake to vent properly, so I returned it to stock.
Mark
Old Jan 24, 2008 | 07:14 PM
grudgeracer
Thanx for info. SO is there a way to keep the oil from getting into the turbo and intercooler? Does replacing the filters in the valve covers help?
Old Jan 24, 2008 | 07:16 PM
6.0superduty's Avatar
6.0superduty
I did mine in about 2 hours. I ran the 1" heater hose under the engine crossmember and over to the downpipe. I took a 4" long 1" outside diameter piece of galvanized pipe from Home depot and cut a 45 on one end. Then I drilled a hole in the front of the downpipe about 4" above the bend that turns the exhaust towards the rear of the truck. The I welded the pipe inside the downpipe with only the 45 and about a 1/4 inch inside of the downpipe. It looks exactly like what is inside of the intake pipe efore the turbo. Then hook up the heater hose and your done. Mine burns off the extra oil while still venting the crankcase exactly as it did before. Hope this helps.
Kyle
Old Jan 24, 2008 | 07:25 PM
4x4Mark's Avatar
4x4Mark
Sounds like a good solution!
Mark
Old Jan 24, 2008 | 08:32 PM
3000 FPS's Avatar
3000 FPS
Kyle
I was just wandering if you still had the cat in place and would this not plug the cat by allowing oil into it. When I raced they called this an evacuation system.
Old Jan 24, 2008 | 10:09 PM
62rag's Avatar
62rag
This comes up every once in a while. Some have recommended a Racor CCV filter. Filters the air so no oil back in, still functions as stock, no fumes.
Old Jan 25, 2008 | 10:16 AM
drakul20us's Avatar
drakul20us
Screw the cat. It's probably the better of two evils, oil in the cat, or oil in your turbo and intercooler. Of course you can always weld in a bong after the cat.
Old Jan 25, 2008 | 10:49 AM
grudgeracer
I do not have a cat or muffler, so will it build up backpressure back in the line if I put it in the exhaust?
Old Jan 25, 2008 | 12:14 PM
3000 FPS's Avatar
3000 FPS
If you put it in like 6.0superduty described in his post then it should draw the crankcase gases out into the exhaust. When I used to race and we did this we would put it a one valve to allow the gases to only go out the exhaust.
Old Jan 25, 2008 | 02:49 PM
drakul20us's Avatar
drakul20us
If you're only restricting a small amount of flow, like a 1/4" the backpressure shouldn't be an issue
Old Jan 25, 2008 | 04:57 PM
6.0superduty
I dont have a cat or muffler. Just MBRP 4" turbo back to a single 5" stack.
Old Jan 25, 2008 | 04:59 PM
6.0superduty
If you still have a cat, you definitly want to put the hase in after the cat. If you start filling your cat with oil, there is a chance of fire if it builds up too much.
