Slip Yolk Replacement
Old Jan 24, 2008 | 04:43 PM
sedly's Avatar
sedly
1976 F250 4x4,front drive shaft extremely sloppy.I replaced all u-joint greased everything,the slopyness is right at the slip yolk.It definately need's to be replaced.What can I do?Try and find a good used one?Can I buy a new one?Get one made?Do I have to replace the entire driveshaft?NP205 trnsfr cse FYI.
Old Jan 24, 2008 | 05:42 PM
75F350's Avatar
75F350
You do not have to replace the entire shaft, but you do need to inspect the splines on the shaft to make sure you do not have any damage to them. They can twist, and wear.
Any good driveshaft shop can help you determine whether or not you can just install another slip joint.
If you look for a used one, a carefull inspection will be in order. You wil also need to count the splines to determine if it will fit. These come in a veriety of sizes, and lengths so make sure you find an exact replacement, or you could damage your shaft. Too long, and it could bottom out under suspension compression. Too short, and the splines could pull out, so measure first, or take the unit with you to compare.
If you have trouble finding some, I have several. Pm me with dimensions, and I can send you some pics I run larger joints in my trucks, but I keep these old parts just in case I run into someone that may need them.
Old Jan 24, 2008 | 05:48 PM
ford_boy_1996's Avatar
ford_boy_1996
I would find a good used one less of a pain. LOL
Old Jan 24, 2008 | 05:51 PM
sedly's Avatar
sedly
The splines on the drive shaft look good.I think it's the inner part of the yolk.I will drop it out again,and take it to a specialist.I'm pretty sure it's just the yolk though.When I find a guy,I will get the the measurement's and spline count at the same time and PM you 75f350,See if you got what I need.Thank's.
Old Jan 24, 2008 | 05:55 PM
sedly's Avatar
sedly
That would be nice.I have to drive a minimum of an hour to get to the nearest wrecker.I'v been on the phone will all of them,not much around for the part's Im looking for.I've started looking for whole trucks privately.
Old Jan 24, 2008 | 06:02 PM
ford_boy_1996
Wink
Oh I see.... I had a friend who put a chevy S-10 front drive shaft in his 79 F-250 .It sounds funny but he did it and it worked he Pulled stuff around in 4X4 and he use to mud the truck with big tires on and it held up to all the abuse....Good luck anyway
Old Jan 24, 2008 | 06:10 PM
ford390gashog's Avatar
ford390gashog
The new slip yoke is 134.00.
Old Jan 24, 2008 | 06:20 PM
sedly's Avatar
sedly
Good luck anyway
Ya, thank's,I kinda need it.
Old Jan 24, 2008 | 06:21 PM
sedly's Avatar
sedly
That seem's kinda pricey.Are they worth it?
Old Jan 24, 2008 | 07:15 PM
ford390gashog
Thats really not to bad of a price. The rear yokes for a D60 are about 100.00. All the slip yokes you will find in junk yards by now are trashed.
Old Jan 24, 2008 | 07:17 PM
sedly's Avatar
sedly
Your probably right.
Old Jan 24, 2008 | 07:38 PM
brownfoot's Avatar
brownfoot
took both my shafts to Carolina Clutch (used to be named Joint and Clutch Service), new slip yokes, new yokes, new u-joints and balanced for about $250.........about 2 years ago
got rid of all my vibrations............yokes were scarry sloppy........should have done it sooner
Old Jan 24, 2008 | 07:49 PM
sedly's Avatar
sedly
Right on!It sure tightened up the drive train when I did the u-joint's.Does the front drive shaft turn when I'm in 2hi,with the divorced np205 trnsfr cse?I think it does.
Old Jan 24, 2008 | 08:05 PM
75F350's Avatar
75F350
It should not turn if the hubs are unlocked and the t-case is in 2wd.
You will get some motion from it, but it does not usually spin at the same rate as the rear, like it would if it was engaged.
Little bit sloppy is not too bad, but if you wheel it hard, it has a better chance of getting damaged because it does not fit properly.
You also run the risk of damaging the splines on the shaft if it fails.
Old Jan 24, 2008 | 08:20 PM
sedly's Avatar
sedly
If it doesn't turn when the hubs's are unlocked,then I'm too concerned about leaving the drive shaft in until I get replacement part's.
