Automatic to Manual trans.
Old Jan 24, 2008 | 01:23 PM
ubahd00d's Avatar
ubahd00d
I'm planning on going from a c6 to a t-19. Truck is a 1986 f-250 4x4. Are the c6 and t-19 the same length, and will the transfer case bolt up to the t-19?
Old Jan 24, 2008 | 06:10 PM
turboman24's Avatar
turboman24
Not sure, but can i ask you how does that Gear Vendors unit work for you. I would think that would be a better setup than a T19 but maybe i am wrong.
Adam
Old Jan 24, 2008 | 06:50 PM
catfish101's Avatar
catfish101
You will have to have a t-19 from a 4x4. A two wheel drive won't work unless you rework it.
Old Jan 24, 2008 | 10:20 PM
ubahd00d's Avatar
ubahd00d
Cool, thanks a lot. That gear vendors works awesome, where i'd normally be running about 3100 or so rpm going 80 or so, i'm running around 2500 rpm with the gear vendor on. Oh, I would be putting the gear vendor with the t-19.
