97 5.4L Exp. died while driving
Old Jan 23, 2008 | 10:27 PM
repairman24's Avatar
repairman24
Cool 97 5.4L Exp. died while driving
I have a1997 exp. with a 5.4 , 125,000 miles. While driving down the freeway it died as if it ran out of gas, 1 month ago I replaced the fuel pump and filter for a different no start condition. Checked fuel pressure 45psi,spark at all plugs,no codes,all sensor readings seem correct. If you hold throttle all the way to the floor it will run at about 300 rpms. I tried a TPS , ECT , I temporarily plugged off the IAC and EGR to rule out them. If you let a vacuum line pull in fuel from a can it runs fine as long as you supply fuel. I know it is a lack of fuel spray from the injectors but not sure what is causing it.
Old Jan 24, 2008 | 09:32 AM
OVER_KILL's Avatar
OVER_KILL
Question
What does the motor sound like when you start it?
Does it crank at all?
Does it make a clicking sound?
Have you checked battery voltage?
Checked all the Fuses?
Old Jan 24, 2008 | 10:19 AM
repairman24
Sounds normal while cranking, battery voltage good 13.1., no odd clicking sounds.
Old Jan 24, 2008 | 10:22 AM
toolman9731's Avatar
toolman9731
check your fuel rails they might be plugged with something
Old Jan 24, 2008 | 08:09 PM
repairman24
how can the rail be plugged, fuel enters on one side and the pressure fitting is on the other side?
Old Jan 24, 2008 | 08:28 PM
antony25's Avatar
antony25
What is your current fuel pressure?
Old Jan 25, 2008 | 08:01 AM
Eddie Hudson's Avatar
Eddie Hudson
Since it runs when you supply fuel from a can, it means there is a problem with your fuel delivery system. Check your fuel pump relay and then see if you're getting power to the fuel pump.
Good Luck
Old Jan 25, 2008 | 08:57 AM
repairman24
the fuel pump runs and supplies 45psi while cranking.
cswett
Modular V8 (4.6L, 5.4L)
Jul 4, 2011 05:17 AM
IlliniJoe
17
Feb 17, 2008 06:07 PM
aa767man
Oct 10, 2007 08:36 PM
Krashed989
Nov 1, 2005 11:28 PM
pdipizzo
Feb 8, 2003 12:16 PM
