The 3/4 ton and 1 ton frames are the same, strength wise. Both are considerably stronger than a 1/2 ton frame.
There's a ton of information out there (check out the fsb forum) on converting to a leaf-sprung solid axle. You have to do some welding to mount the front spring hangers though. It can definitely be done.
