hi guys, i just joined this sight, its great! I've got a 2000 250 with 247k on it, what are the best fuel additives for my truck? what have you all heard about useing 2cycle oil?
I've been told to never use anything synthetic as the additives may be hard on the injectors. I usually use something that cleans lubricates and boosts cetane at the same time. Kill all the birds with one one rock......
With the new ULSD, you need to add something with good lubrication properties to replace the sulfur (which served to lube the fuel pump and the injectors). The Power Service white helps, but not as much as this stuff. It's also a cetane booster.
Powerservice grey bottle most of the time and white bottle when the temperature gets cold. Don't use 2 stroke oil in these motors the injectors are way to sensitive and expensive.
bio diesel lubes better than optilube! and you only need to run b-2 or 2%biodiesel to acchieve better lubrication, so thats roughly .75 gallons of b-100 to a full 33 gal. tank of diesel!
What about the cetain booster by motorcraft that ford sells. Is for injectors and it makes mine stop all the black smoke. Has anyone else tried it?
I use the ULSD formula cetane booster by Motorcraft in my 05 excurion with the 6.0. and my 08 F250 with the 6.4. The excursion seems to run better, and better milege.
