I am clueless here
Old Jan 23, 2008 | 02:07 PM
385seriesHemi's Avatar
385seriesHemi
Question I am clueless here
Ok I have a question here about camshafts. I see different Lobe seperations in books and I was wondering what do the differences in the degrees benefit for performance?
Old Jan 23, 2008 | 03:04 PM
Conanski's Avatar
Conanski
In very general terms, the longer the duration the higher in rpms the peak HP will be. The air flow capacity of all components on the engine, the intake, heads, and exhaust also play a role in determining the total amount of HP a motor is capable of generating. It's a pretty complicated relationship, so the best way to really see how all these parts combine to produce a power curve is to model them with software like Desktop Dyno.
Old Jan 23, 2008 | 03:12 PM
385seriesHemi
So the lobe seperation does not effect the performance if I ran a 112 degree lobe seperation compared to a 110 degree?
Old Jan 27, 2008 | 09:00 AM
wayneF250's Avatar
wayneF250
The 112 LSA will give u more Vaccum than the 110 LSA, the tighter the LSA mean that both of the vales are open the same time, which gives the "lumpy" idle.......I THINK................Ck me on this
Old Jan 27, 2008 | 11:19 AM
Conanski's Avatar
Conanski
Yes.. every parameter affects performance. As stated a smaller LSA will generally deliver less or more unstable low rpm vacuum, and the SD EFI system most of these trucks are equipped with won't tolerate anything less than 114 deg LSA, unless total lift and duration are very small. Even stock MAF computers will have difficulty with LSA below 110deg, but as usual it depends on a lot of other things.
Old Jan 29, 2008 | 03:36 PM
385seriesHemi
Yeah, thanks for gettin little more in depth to explain it.
