Cold Weather Starting
Old Jan 23, 2008 | 11:26 AM
geno3124's Avatar
geno3124
The other day at only 40 deg. my 96 7.3 would not start. Tryed it a couple of times with no luck then I noticed that the glo plug wait to start light did'nt come on anymore. I blew a 30 amp fuse.Changed it and the lite came no again upon trying to start and the second fuse blew .Third fuse instaled,this time disconected pasenger side rear glo plug cable and the lite stayed on like normal and motor started but was running rough ,not all cylenders hitting I guss, so I then plugged the cable back in while it was running and it smothed out great but then shut off a few seconds latter.Blew another 30 amp fuse.I figured it must be a short or a bad gp on that bank.I then plugged the heater in, let it sit over night.The next morning,motor all toasty warm, I put a new 30 amp fuse in,and everything worked fine,motor started right up and running great.Did not blow any fueses.I cycled it several times and no problems.Let it sit for a few hours ,heater unpluged,and still had no problems, started right up.Sounds like "TWILITE ZONE".What do you think took place and do you think I should change the gp's.I only have 145000 on the truck and it's all original in great shape,like new condition.I don't want to get stuck anywhere.I have a E450 turbo charged van with a walk in service body plum full of tools I can't afford to loose to vandels on the side of the road.I live in N.O. Louisiana.
Can anybody help me?
I am new to this site Thanks
Old Jan 23, 2008 | 12:05 PM
skittlejr's Avatar
skittlejr
i assume you unplugged the outside valve cover harness which would be why you were running rough (only one six cylinders). probably a burnt up under valve cover wiring harness. i would pull the lids and check all four. they are notorious for going bad. some one correct me if i am wrong, but i am thinking that as the glow plugs go bad and the resistance rises this creates heat in the harness causing them to burn up and results in shorted wires causing the fuse to blow. i have had the harness burn up but never the fuse blowing situation. after having the block heater plugged in, i am thinking that the gp's didn't draw as much current as when it's cold so that's why the fuse didn't blow, but that is just speculation.
Old Jan 23, 2008 | 12:08 PM
u2slow's Avatar
u2slow
Not exactly sure why you are blowing fuses. However, if the GP light is not coming on, the GP relay/solenoid may not be making contact reliably.
Running the block heater is extra important if you are down a few GPs. My old Chevy 6.2L was down to 2 working ones before I had enough and changed them all out. .
The colder weather right now has me wondering about the GPs on my own service van ('97 E350). I'm getting the hard start and big cloud of grey smoke when it finally catches.
Old Jan 23, 2008 | 12:27 PM
geno3124's Avatar
geno3124
Hey guys,Thanks for the info.I am new here and Iam having a hard time trying to figure out how to navigate this web site.I am not a computer geek,just nuts and bolts freak.My truck is a van and I have a lot of things to take off just to pull the covers and look for a problem,looks like a time consuming job that needs tiny monkey hands to get everything loose ,but I have no choice.I think I will replace all the gp's with motorcraft ones, and check the wires under covers.Any tips on what to be causious of? I read horror stories of broken gp stuck in the heads.I don't need that.My lively hood depends on this truck and money is tight.Can't afford to put in a shop.Thanks
Old Jan 23, 2008 | 12:53 PM
powrstrkr's Avatar
powrstrkr
I'm pretty sure the Wait To Start light is controlled by the PCM. If the GPR is bad the light will still come on, unless the fuse blows. I agree something is probably going on under one or both valve covers - bad GPs or shorted harness(es). Good luck doing that work on a van. It's tight under there.
Old Jan 23, 2008 | 01:02 PM
MADVAN's Avatar
MADVAN
WTS lamp is independent of the GPR.
The WTS will allways come on for a lamp self check at startup.
Bill
Old Jan 24, 2008 | 11:41 AM
skittlejr's Avatar
skittlejr
https://www.ford-trucks.com/forums/6...in-engine.html
read this...plan on at least one or two being stuck. that thread should give you what you need, if not, post back more questions.
Old Jan 24, 2008 | 03:26 PM
Cuda_jim's Avatar
Cuda_jim
If you are blowing #22 fuse under the hood, your fuel heater in the filter housing is shorted. You can unplug it unless you live in the arctic. Not sure if your van is the same under the hood but here's a pict of the plug.
https://www.ford-trucks.com/forums/5...ht=fuel+heater
Old Jan 24, 2008 | 10:08 PM
geno3124's Avatar
geno3124
Hey Jim,I will check that out.Sounds good to me.There is so much I dont know about a diesel,,,,,I bet rocket scientist go to diesel school to get qulified to work on the space shuttel.HA! HA!
Thanks and you have a good day!
Old Jan 29, 2008 | 08:38 PM
k_conner's Avatar
k_conner
have a 96 f350 that did the same thing. turns out I had melted glowplug harness on more than one side. got to where it would start and then die about 5 seconds later. the job was easy but it was time consuming however saved a ton of money. id pull the valve covers and look....good luck
bismic
Aug 10, 2015 10:35 AM
'50'sFever
Ford Truck Parts for Sale
Sep 27, 2014 05:25 AM
351Cleveland C4
The Next Generation
23
Sep 23, 2013 06:00 PM
charon61285
Feb 23, 2011 12:31 PM
Damon_Tirerack
Appearance & Dress-Up
Aug 18, 2009 03:07 PM
