Open diff to LS diff 8.8
Old Jan 22, 2008 | 10:19 PM
ech0sh4y's Avatar
ech0sh4y
I have a 8.8 with 3.08 open right now.. i have the 300 6 cyl with a 5 spd and 35s.. my questions is: I don't want to change the gears by my self i'll get that done professionaly, but can i add a limited slip? or do you need to set the backlash and stuff like that? Also what gears do you guys recommend i swap out to?
Old Jan 23, 2008 | 12:51 AM
85e150's Avatar
85e150
When you get your gears swapped, you can have the locker, limited slip or whatever installed at the same time. Feast your eyes upon all things 8.8:
http://www.currieenterprises.com/ces...re.aspx?id=960
You have a 5 speed with a .80 OD perhaps? And 35s. And the six. And so you might want to run about 2300 rpm at 65 in top gear.
http://www.novak-adapt.com/knowledge/gearing.htm
This would suggest 4.56s for your combo which will give you 2276 rpm at 65 in top gear. 1000 rpm to go if you want to out run the troopers, and your lower gears will do well with them I would think. You can plug in your numbers above and figure out your speed in each gear etc.
Old Jan 23, 2008 | 10:43 AM
Blurry94's Avatar
Blurry94
An Eaton LSD is a stout unit I would personally go with 4.10's, you'll notice a huge difference over the 3.08's you have in there now.
Old Jan 23, 2008 | 12:17 PM
ech0sh4y's Avatar
ech0sh4y
Well I just found a Ford 9 with 3.73 Limited slip for 100 bucks... Is this a direct bolt up? Its out of a 78 f150 Bigger is better =D
Old Jan 23, 2008 | 03:37 PM
85e150's Avatar
85e150
What year is your truck? The 9 inch means swapping the entire rear axle housing, possibly a modified driveshaft, no VSS which may mean no speedo and no anti-lock brakes. Fix your 8.8.
on edit: I looked at your profile. Is this for your '96 F250? If so, you do not have an 8.8, and the 9 inch won't work at all.
