Paging Col Flashman
Old Jan 22, 2008 | 06:10 PM
sandhillmike's Avatar
sandhillmike
Question Paging Col Flashman
I looked at your gallery, but couldn't really make out the engine mounts you're using for the 300. I keep waffling on what I want to do, but I now have 3 viable choices. 300 I6/3spd with OD, 351W/C4 and 292/stock 3 or 4 spd combos. Just wanted a little info on the 300 set up. Thanks
Old Jan 23, 2008 | 11:55 AM
59flatbedford's Avatar
59flatbedford
well im no expert but the 300 is a really strong engine with lots of torque and are super reliable that and u have a lot of options for transmissions. there might even be a 5 speed u could put in.
Old Jan 23, 2008 | 03:29 PM
Col Flashman's Avatar
Col Flashman
I used the 300's Factory engine mounts that are mounted on the sides of the block, as the location matched close enough of those from the original 223 I-6's engine mounts.
The 300 I-6 used LT. 3-on-the-Tree, LT. 3-on-the-Tree w/ O.D., Med./H.D. 4 or 5-on-the-Floor, C-4, C-6, A.O.D., E4OD, etc.
