Auto lamp is chattering
Old Jan 22, 2008 | 05:29 PM
Jzinkiewicz's Avatar
Jzinkiewicz
It's dark and I turned the lamp selector all the way counter clock wise to the auto lamp position. Started chattering. Noise sounds like it coming from behind the radio. Door Ajar is doing it's own thing, sometimes illuminating when the door is shut sometimes not, power dr locks locking at 5mph(the way it's supposed to), sometimes not. I hope it's not the GEM. Any suggestions.......Just had the instr cluster replaced for $700.
Old Jan 22, 2008 | 06:21 PM
Ponyboychris's Avatar
Ponyboychris
Try cleaning the battery posts on both batteries. Sometimes, bad connections or dying batteries can cause the relay chatter and other problems. How old are they?
Old Jan 22, 2008 | 06:23 PM
Jzinkiewicz
Batteries, I don't know but I just cleaned one the other day
Old Jan 22, 2008 | 06:57 PM
Ponyboychris
Clean the post real good first and see if the chattering stops. If they still do, have them tested. If one is bad, replace both of them as a set. Dying batteries caused my relays to go nuts.
Old Jan 23, 2008 | 06:32 AM
Jzinkiewicz
Really, I don't know how to test them but I'll find out. I think there're originals, 2002' How long did your's last?
Old Jan 23, 2008 | 12:27 PM
AustinS's Avatar
AustinS
Could be the switch in the door too. The switch is part of the latch mechanism. Sometimes a good dose with WD40 will help if that's the problem.
Austin
Old Jan 23, 2008 | 12:46 PM
Trailblazed's Avatar
Trailblazed
I'm also getting a clicking every once in awhile. Its like the daytime lights are trying to come on and then go off. I think my noise is coming from behind the multifunction switch... my multifuction switch for my head lights don't work now.. only the high beam selection. First, my low beams died, then a couple weeks later my day time running lights went, now I just have my high beams and fog lights. Fog lights are on a toggle switch though.
Old Jan 23, 2008 | 01:09 PM
Ponyboychris
I replaced them in Jan of 2006 at 90k miles. They were on their last legs.
