Question that needs answering
Old Jan 21, 2008 | 10:08 PM
pro70golfer14's Avatar
pro70golfer14
What do people mean when they say top end? If someone could answer this it would be nice thanks?
Old Jan 21, 2008 | 10:40 PM
BEWOLD's Avatar
BEWOLD
top end is usually associated with the cylinder heads and valve train (maybe intake and fuel system, depending on who your talking to). bottom end is your rotating assembly (crank,rods,pistons) and block.
Old Jan 22, 2008 | 10:32 AM
Mike G's Avatar
Mike G
First off, welcome aboard.
Secondly, top end can refer to two things... Top end as in the top end of the motor (as previously described), or top end, as in the top end of your rpm range. If you are looking for parts to help your top end, as in performance, you will look to items that will increase the limit of your rpm range or maximize it's performance once there.
--Mike
