76 highboy steering damper
Old Jan 21, 2008 | 09:42 PM
samtye's Avatar
samtye
is it possible to add a steering damper with the stock slave cylinder? I'm running 36.5 x 14 tires and its getting annoying fighting the steering wheel.
Old Jan 21, 2008 | 10:02 PM
4starcstms's Avatar
4starcstms
Im Sure there is. Ive got one sitting @ the house, but have never tried to put it on. One of those things that I'll get around to eventually!
75F350's Avatar
75F350
Sure it is possible, but your steering issues are probably an indication of other problems. Steering dampers are really a band aid to a steering problem, and not really the solution. Find out why you have to struggle, or fight the wheel and you will be much happier with the results.
Old Jan 21, 2008 | 10:09 PM
samtye's Avatar
samtye
yeah, i noticed the passenger side tie-rod boot is missing, maybe i'll replace those first. thanks
Old Jan 31, 2008 | 09:24 PM
tomcasino's Avatar
tomcasino
I tried but there's not much room with the ram-assist cylinder in the way. It would take a bit of fabricating if you really needed to put one on. Like what was said above, that's just a band-aid for other problems.
