Sponsored by: Real Truck
Possible Seal bad????
Old Jan 21, 2008 | 09:21 PM
bmvtr's Avatar
bmvtr
Exclamation Possible Seal bad????
I noticed the other day while cleaning my truck and it seems that there is a black rubber ring that moves around where the end of the front axle. Ill try and get pictures durring the day. If its a problem should i just replace my ball joints if i have to replace stuff? any thoughts or suggestions are appreciated.
Old Jan 21, 2008 | 10:31 PM
3000 FPS's Avatar
3000 FPS
I have an 01 and both axles right now have that black rubber ring that moves around where the end of the front axle is. I believe it is a dust seal for the front hub and part of it has come off. I am going to pull the front hub apart so I can replace them along with the orings and clean the needle bearings. I do not believe it has anything to do with ball joints.
Old Jan 22, 2008 | 05:40 AM
rich250's Avatar
rich250
if it's on the inner side towards the axle housing it's the dust seal for the axle,if it's out towards the wheel it's the knuckle seal,either way if your gonna tear things apart I would replace both of those seals,the dust seal is gravy but the knuckle seal is a real pain to get on the axle unless you buy or make a driver for it.ball joints are up to you if they are tight you could leave them in and just put grease fittings in them or replace them with moog greasable ball joints.
Old Jan 22, 2008 | 02:05 PM
bmvtr's Avatar
bmvtr
Thanks guys sounds like a fun weekend project
Old Jan 22, 2008 | 03:17 PM
Eng1Driver's Avatar
Eng1Driver
On my 2008 the dust seal for the stub shaft does move some. I confirmed this is normal with 2 other brand new trucks on a dealers lot.
