Sponsored by: Auxito
differential noise
Old Dec 5, 2001 | 11:06 PM
Glenn See's Avatar
Glenn See
Post differential noise
Have a '97 LWD X-Cab with 73K miles. It has started having a howling whine in the differential more pronounced between 40 mph and 60 mph.
I have been driving pickups since the late 40's and have never had any rear drive train problems. The truck has very little towing miles and 99% of the miles have been without a load.
I have been told it is bearing problems.
Have any of the readers had troubles like this, and if so, what was the solution and, more importantly, the cost? Thinking that it might be the center bearing, I had it replaced. I cannot see it because of a rubber boot, but it must be gold-plated. It cost $125 including shipping charges.
Old Dec 15, 2001 | 07:57 PM
Glenn See's Avatar
Glenn See
>40 mph and 60 mph.
>load.
>charges.
Old Dec 16, 2001 | 03:42 AM
noremac19's Avatar
noremac19
differential noise
I had a 94 f-150, with a howling noise, and i had to get my diff rebuilt. It whined for about a year, then it started clunking, then i took it in.
Old Jan 7, 2002 | 03:15 PM
jurij's Avatar
jurij
My name is George. I have a 98 4.6L, 3.08 rear end. At 52k miles just after I bought it from an individual I noticed the classic "high speed whine". I asked around, took it to two Ford dealers who had two different sets of opinions, then finally took it to a guy who everyone around here claims is the best rear end man around. After driving it he concluded without a doubt that it was the rear end. I of course was up the creek without a paddle. It cost me $800 to replace. The important thing is to replace it with the correct synthetic fluid.
It may last a long time or it might not. I couldn't put up with the noise.
Sorry for the bad news.
Old Jan 7, 2002 | 09:10 PM
Ultramagdan's Avatar
Ultramagdan
differential noise
[updated:LAST EDITED ON 07-Jan-02 AT 10:13 PM (EST)]It is also possible that a wheel bearing has gone bad. If that's what it is I would look for some oil leakage at the axle shaft when you remove the brake drum/wheel if you have rotors.
If it is the rear end - they are not as hard to remove as you would think.
Old Jan 8, 2002 | 12:56 PM
jaybeesmith's Avatar
jaybeesmith
i have a 97 with only 43K on it, and i have already had the rear end rebuilt.
while having the breaks checked, the tech noticed bearing grease/oil on the inside of the drums and on some of the hardware. the reason for this was the seals were going bad, which was due to the bearings going bad,..I ended up having both sides rebuilt.
luckily it fell under my ext. warantee. otherwise,..i think i would have put up with it until 72K as you have.
Old Jan 31, 2002 | 04:07 PM
buenabooter's Avatar
buenabooter
i have a 2001 f150 4.6 aut. with 5000 miles. i have a high piched noise simular as to the one you describe, it is very evident as the weather gets colder,it also seems very inside the cab. could this be a differential problem as well?
Old Feb 1, 2002 | 08:00 PM
broncoman85's Avatar
broncoman85
differential noise
Cornell1
Jan 1, 2014 05:48 PM
stkelly
Mar 13, 2013 08:30 PM
John L
1983 - 2012 Ranger & B-Series
Jan 10, 2005 01:02 PM
overtow
Feb 5, 2004 04:30 PM
