6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
08 Powerstroke, non ULSD fuel?
Old 01-22-2008, 12:53 PM
99f250psd's Avatar
99f250psd
99f250psd is offline
I would put in a 100 gal aux fuel tank and fill up before crossing the border. $800-$1000 dollars for the fuel tank (that I want to buy anyway) would be much cheaper than voiding your warranty for future claims.
Old 01-22-2008, 05:00 PM
kw5413's Avatar
kw5413
kw5413 is offline
6.4 EGR valve and particulate filter (DPF) failures due to high sulfur fuel:
The 6.4 PowerStroke is designed to run on ultral low sulfur diesel (ULSD) fuel, which has no more than 15 PPM sulfur content. Using high sulfur fuel (greater than 500 PPM sulfur) can cause corrosive damage to the EGR valve and DPF. Use of high sulfur diesel can cause emission system component malfunction and cause the check engine light to come on. Broadcast Message 0346.
Old 01-22-2008, 05:34 PM
hunter08's Avatar
hunter08
hunter08 is offline
Hello All,This is my first post but I have been watching for a while.I was asked if I run lsd fuel or ulsd fuel by a tech at Basil ford in buffalo ny where my truck is right now with a blown engine.
Old 01-22-2008, 05:42 PM
dascro's Avatar
dascro
dascro is offline
Running LSD or ULSD would have no impact on a blown engine. Obviously the tech is so overwhelmed by the new technologies that he has forgotten about the basic engine.
Old 01-22-2008, 05:43 PM
kawtiper's Avatar
kawtiper
kawtiper is offline
ok spill the beans, how did you blow the engine on a new truck? inquiring minds want to know.
Old 01-22-2008, 05:49 PM
kawtiper's Avatar
kawtiper
kawtiper is offline
Since the sulfur is the lube for a diesel I would think the higher content would be better on the motor, excluding all the peripherals of course.
Old 01-22-2008, 07:43 PM
richfaa's Avatar
richfaa
richfaa is offline
Page 31 Powerstroke diesel owners manual..."Using low sulpher diesel fuel(16-500ppm) or high sulpher diesel fuel (greater than 500ppm) in a 6.4L diesel engine designed to use only Ultra Low Sulpher Diesel fuel increases the likelihood of engine oil dilution with fuel which may lead to major engine damage. Engine damage from using the improper type of fuel is not covered under your warranty"..So it is written..Am I to understand that folks on this forum are telling me to disregard that statement by Ford.
Broadcast msg 0346 is titled 6.4 EGR valve and particulate filter failures due to high sulpher fuel.
Old 01-22-2008, 08:06 PM
hunter08's Avatar
hunter08
hunter08 is offline
Well I just don't no how I blew the engine.I just believe it was a bad engine from the start.I baby my vehicles.I really dont think that the fuel was the problem although it did run like crap when I had to fill up with lsd one time.
Old 01-22-2008, 08:31 PM
Larry NCKS's Avatar
Larry NCKS
Larry NCKS is offline
Originally Posted by CATANG MOTORSPORTS
Personally I feel the big difference between those that are not haveing regen issues and those that are, is caused by running something other than the ULSD fuel, either intentionally known or accidently via not paying enough attention to the labels or perhaps some gas stations are buying the cheaper LSD version and marketing it as ULSD fuel,
Your feelings are not supported in my case! I religiously use ULSD fuel and CJ-4/SM oil. I have regen issues. As far as stations, their pumps/tanks are tested before the ULSD label is placed on the pump. They are subject to inspection. I don't believe many, if any will risk the consequences of being sloppy with what fuel is in ULSD labeled pumps.
Old 01-22-2008, 09:09 PM
origcharger's Avatar
origcharger
origcharger is offline
Sulfer is not the lube for a diesel, it isn't even a desired component of diesel fuel.
Its the process used to remove the sulfer that alledgedly reduces fuel lubricity, but ULSD fuel is required to meet standards for lubricity and the engines are designed to run on it.
Old 01-22-2008, 09:50 PM
REELNAUTI4U's Avatar
REELNAUTI4U
REELNAUTI4U is offline
<TABLE><TBODY><TR><TD vAlign=top width="100%">Looks like they can be modded for #2 & LSD ?: https://www.ford-trucks.com/user_gal...p?albumid=32299
</TD></TR></TBODY></TABLE>
Old 01-22-2008, 10:01 PM
chaparro's Avatar
chaparro
chaparro is offline
Originally Posted by rob_nc
I think this statement is being used as a scare tactic. It will NOT harm the engine in any way, but it will damage the emissions equipment.
Damage to the engine or the emision equipment is the same ^&*^^$%$&%. It will void the warranty. There is a little manual when you buy a new truck. The manual states ONLY ULSD period.
  #28
Old 01-22-2008, 10:20 PM
REELNAUTI4U
  #29
Old 01-23-2008, 05:25 AM
No1Hookman's Avatar
No1Hookman
No1Hookman is offline
That message is in my owners manual as well, nothing new there. Oh, and I'm in the US of A.
  #30
Old 01-23-2008, 06:56 AM
rob_nc's Avatar
rob_nc
rob_nc is offline
The corrosive qualities of LSD are not new. In fact, the intake manifolds used to be coated internally to prevent corrosion from EGR gasses. It's called sulfuric acid when mixed with water.
Quick Reply: 08 Powerstroke, non ULSD fuel?
