08 Powerstroke, non ULSD fuel?
on
6.4 EGR valve and particulate filter (DPF) failures due to high sulfur fuel:
The 6.4 PowerStroke is designed to run on ultral low sulfur diesel (ULSD) fuel, which has no more than 15 PPM sulfur content. Using high sulfur fuel (greater than 500 PPM sulfur) can cause corrosive damage to the EGR valve and DPF. Use of high sulfur diesel can cause emission system component malfunction and cause the check engine light to come on. Broadcast Message 0346.
Page 31 Powerstroke diesel owners manual..."Using low sulpher diesel fuel(16-500ppm) or high sulpher diesel fuel (greater than 500ppm) in a 6.4L diesel engine designed to use only Ultra Low Sulpher Diesel fuel increases the likelihood of engine oil dilution with fuel which may lead to major engine damage. Engine damage from using the improper type of fuel is not covered under your warranty"..So it is written..Am I to understand that folks on this forum are telling me to disregard that statement by Ford.
Broadcast msg 0346 is titled 6.4 EGR valve and particulate filter failures due to high sulpher fuel.
Originally Posted by CATANG MOTORSPORTS
Personally I feel the big difference between those that are not haveing regen issues and those that are, is caused by running something other than the ULSD fuel, either intentionally known or accidently via not paying enough attention to the labels or perhaps some gas stations are buying the cheaper LSD version and marketing it as ULSD fuel,
Originally Posted by kawtiper
Since the sulfur is the lube for a diesel I would think the higher content would be better on the motor, excluding all the peripherals of course.
Its the process used to remove the sulfer that alledgedly reduces fuel lubricity, but ULSD fuel is required to meet standards for lubricity and the engines are designed to run on it.
<TABLE><TBODY><TR><TD vAlign=top width="100%">Looks like they can be modded for #2 & LSD ?: https://www.ford-trucks.com/user_gal...p?albumid=32299
</TD></TR></TBODY></TABLE>
Originally Posted by rob_nc
I think this statement is being used as a scare tactic. It will NOT harm the engine in any way, but it will damage the emissions equipment.
#28
Originally Posted by chaparro
Damage to the engine or the emision equipment is the same ^&*^^$%$&%. It will void the warranty. There is a little manual when you buy a new truck. The manual states ONLY ULSD period.
#29
Originally Posted by REELNAUTI4U
#30
