Towing
Old Jan 21, 2008 | 06:54 AM
Bigtony4's Avatar
Bigtony4
Towing
What is the limit for towing with a 2004 scsb 4x4 Lariat with the tow package? I know it was around 9000lbs but I want to be sure. I am looking at a new camper and don't want to go too heavy.
Old Jan 21, 2008 | 09:01 AM
fordxl68's Avatar
fordxl68
2004 specs
With 3.73 gears and 5'box 7800lbs. with 6' box 9300lbs. if you want to check for yourself google 2004 F150 specs
Old Jan 21, 2008 | 10:23 AM
osbornk's Avatar
osbornk
When you consider a trailer, keep in mind the advertised weight is for the base trailer. Accessories (AC, awning, microwave, spare,etc) typically adds about 500 lbs to the actual weight. Then you need to add the weight of your "stuff" which can easily be an additional 1,000 lbs. or more and the weight of the folks in the truck. You don't want to go over about 80% of the GVWR. Once you get in this territory, you need to go to a HD truck.
Old Jan 21, 2008 | 05:59 PM
Bigtony4's Avatar
Bigtony4
Thanks. Going to go with Coachmen with a base weight of 5800lbs.
Old Jan 21, 2008 | 06:06 PM
ford390gashog's Avatar
ford390gashog
whats the wheelbase, gear ratio and engine size? we need more info
silentrunning
Feb 28, 2010 03:00 PM
tractorman41
Jul 21, 2009 08:01 PM
rodriguezfords
All Things Towing
Mar 28, 2008 07:37 AM
4.0 Beast
21
Sep 20, 2004 07:54 PM
endroad_06
1978 - 1996 Big Bronco
Apr 22, 2004 12:26 AM
