Aerostar Ford Aerostar
Noisy Front Right Suspension
Old Jan 21, 2008 | 01:10 AM
SgtJoe's Avatar
SgtJoe
Hello everyone,
I'm getting a squeeking noise in the right front suspension whenever it compresses. Will a spray of some lubricant fix it? If so, could someone recommend one for me?
Thanks!
Old Jan 21, 2008 | 01:32 AM
Pablo-UA's Avatar
Pablo-UA
Usually this sound appeare when lower arm rubber insulators are worn. But check all carefully from underneath. Ask someone to rock your van and hear for unusual sound.
Old Jan 21, 2008 | 03:27 AM
96_4wdr's Avatar
96_4wdr
pablo is right,
pinpoint the noise first
shotgun spraying the rubber/neoprene suspension components with an oil/grease based product causes deterioration of the rubber.
may also be failed shock broken seal bent shaft
upper suspension arm bushings worn out
or a body/frame part on rt. side
how does it drive? tracking and wind stability?
Old Jan 21, 2008 | 09:13 AM
SgtJoe's Avatar
SgtJoe
Thanks everyone
It drives great. One morning it started squeeking. I tried bouncing it up and down in the driveway to reproduce the noise, but it remained silient.
Old Jan 21, 2008 | 11:23 AM
aerocolorado's Avatar
aerocolorado
Upper ball joint wear will do this also, especially when under compression such as slowly bumping over a curb/driveway culvert. Not usually a high pitched squeek though, more of a loud "crunch" or "gronk" noise. Hard to reproduce by bouncing. Upper joint wear is a common malady.
