steering stabilizer question
Old Jan 20, 2008 | 04:47 PM
tritonboy01's Avatar
tritonboy01
I installed a meyer snowplow on my 1995 f-150 4x4 5.8l this weekend and had to remove the steering stabilizer to fit the mount on....How is this going to affect the truck? I seems like since i removed this the tires leen a little? is the normal
Old Jan 20, 2008 | 04:50 PM
kcb37's Avatar
kcb37
That may help that, all a steering stabilizer is dezigned to do is help keep the wheels striaght. On something with small tires you don't need it, but when you get into bigger tires it start to come into play.
Old Jan 20, 2008 | 04:53 PM
toddol1971's Avatar
toddol1971
Theres no way removing that will make your tires lean. My guess, I think the weight of your plow is causing your springs to sag which in turn causes your tires to lean a little. You could also have bad ball joints but I doubt it. Get some stiffer springs & you'll be all set.
