Clutch dosent work when cold
Old Jan 20, 2008 | 04:01 PM
scrapyardking's Avatar
scrapyardking
Hello I have a '94 ranger with a hydraulic clutch. When its cold out the clutch pedel stays in the down position when pressed and the truck will not go into gear. I half to push it into the garash and let it thaw for it to work.
What might cause this?
Old Jan 20, 2008 | 04:08 PM
Greywolf's Avatar
Greywolf
Water in the lines or reservoir. If it forms ice or ice crystals it will jam the mechanism until it thaws.
Old Feb 11, 2008 | 05:33 PM
scrapyardking
Update: I changed out the fluid and blead the system and it was fine until this morning when it was below zero outside. It did the same thing pedal goes to the floor but the clutch dont work.
Could anything else in the system not work when cold?
I cant afford te be late to work anymore.
Old Feb 11, 2008 | 05:43 PM
Greywolf's Avatar
Greywolf
The only common denominator I can think of is extreme cold causing thickening of the hydro fluid - and that should only be if there is water in it.
Weak springs in the clutch master, on the slave, or a bad pressure plate might contribute to the problem.
There isn't much else in the system, but I do know it's a time consuming pain to completely and thoroughly flush out the fluid in the system...
I also don't really believe the slave cylinder pre-load spring would go bad.
I can't think of a reason why a pressure plate would be stuck only when very cold either.
You may just have to garage it in the cold season, until you can go through the entire system and check things out.
I'd be frankly tempted to get a line fitting from a frame at a scrap yard so that you can drain out every drop of fluid from the slave cylinder and be sure new fluid isn't mixing with the old.
Old Feb 11, 2008 | 06:43 PM
rubydist's Avatar
rubydist
If the release springs on the clutch are weak, it will be more likely to stick when cold as there is more resistance to the parts moving.
Does it behave completely normal when warm, or is the pedal somewhat soft all the time?
Old Feb 11, 2008 | 06:47 PM
Greywolf's Avatar
Greywolf
There it is - if the action is weak normally, it won't work when the cold makes the fluid thicker.
Old Feb 12, 2008 | 10:52 PM
Hank85713's Avatar
Hank85713
I would suspect a bad mastercylinder. change it then expect the slave to go if it is weak. will depend on the miles on it.
Check at the clutch pedal for fluid leaks in the cab where the rod comes in and also under the master in the engine compartment. Kind of a PIA to change the master but easire than the slave (trans removal here).
Old Feb 13, 2008 | 06:26 PM
Greywolf's Avatar
Greywolf
True.
The master doesn't call for a tranny unbolt and slide-back to get at it.
But the slave holds a lot of fluid, and the Q/D connector won't allow what is in the bottom of the slave cylinder to be drained out unless you make something to do that.
Still - even if ice forms in the slave cylinder it should extend and retract if the master cylinder has enough pressure going into the lines. Bleeding it to any degree should rid the M/C of icing.
Unless the whole system is just plain loaded with it.
I wonder now if there is any fluid seeping from the bellhousing that would indicate the S/C has been frozen and damaged.
Old Feb 13, 2008 | 06:47 PM
scrapyardking
No leaks, I have been parking it in the garash at night and that seems to help alot even tho its not heated.
Old Feb 13, 2008 | 08:02 PM
Greywolf's Avatar
Greywolf
I don't think all of the old fluid is flushed yet.
And I just don't know of a SURE way to be certain it is short of pulling that slave CYL.
The only device I know that can do that for sure is to pull it, drain it, and BENCH BLEED it.
Not even a pressure bleeder can do it thoroughly as the design stands.
THEY DO NOT HAVE A LOW POINT DRAIN
I'd write a link to a page to talk to the engineers behind that, but it's late at night and they should have thought of it at some point in the last many years - so that it would be incorporated in the design by now.
It isn't, so we move on....
Old Feb 13, 2008 | 09:37 PM
bazzman1953's Avatar
bazzman1953
Until you get to the root of the problem put some sort of heat under it [droplight, spotlight] at night to keep it heated until the problem is solved.
coolfeet
Sep 11, 2015 08:02 PM
bigred177
40
Sep 22, 2014 08:39 PM
rost495
Apr 17, 2012 11:00 AM
rsvicary
Mar 29, 2009 05:54 PM
Mr Baja
1978 - 1996 Big Bronco
Nov 30, 2001 01:38 AM
