460/390 flywheel
Old Mar 29, 2002 | 03:44 PM
tbolt 460's Avatar
tbolt 460
460/390 flywheel
can some tell me if there is a difference in the EARLY 460 and a 390 flywheel I have what i was told is a 460 flywheel(early one,no weight) and there is NO casting numbers or date code
Old Mar 29, 2002 | 04:32 PM
greenhighboy's Avatar
greenhighboy
460/390 flywheel
There were no 460 flywheels until the 80's.There were 429 car flywheels.There isn't any difference in a 390/429,flywheel they used the same clutch and were balanced the same.A 360 flywheel uses a smaller clutch than a 390 so they are a little different.
Dennis
1979 F-250 4x4 460 4-speed 33"s
1977 Highboy 429 4-speed 35"s
1969 Ranger on a 1978 F-250 4x4
frame 466 560HP 4.10's 33"s
Old Mar 29, 2002 | 04:49 PM
tbolt 460's Avatar
tbolt 460
460/390 flywheel
a 429 flywheel is bigger than a 390 and 460 one.
Old Mar 30, 2002 | 07:37 AM
greenhighboy
460/390 flywheel
I had one that had the numbers on it off of a car 429 and it was the same as a 390.My'79 has a car bellhousing on it with a 390 flywheel and the starter works.If the 390 flywheel was smaller I wouldn't think that the starter would enguage the starter ring.
Dennis
Old Mar 30, 2002 | 09:40 PM
El Guapo's Avatar
El Guapo
460/390 flywheel
