Cold!
Old Jan 20, 2008 | 10:29 AM
WALJON's Avatar
WALJON
Cold!
I just started my truck after a cold overnight temp of -31c it was plugged in of course it started rite up it was rough though I then hit the high Idle to run back in the house and it went into limp mode check engine light so I turned it off and started it again but this time let it Idle a bit before I hit high Idle it was fine after this
I am using 10/30 at the moment and if the weather continues this cold I will have to change to 0/40
until this cold snap I was fine with 10/30 just goes to show you should always do what the manufacturer recommends
thanks
Old Jan 20, 2008 | 11:31 AM
fordman837000's Avatar
fordman837000
I still run the thick stuff maybe I should change it? mine has gone into limp mod a few times before just shut off the high idle and turn it back on and its usually fine after that it doesn ' t act up often.
Old Jan 20, 2008 | 01:02 PM
WALJON's Avatar
WALJON
YEAH it did it to me last year one time as well but it still had 15/40 in it
long rang forecast is calling for cold like this till the end of the week so I might just bear with it rather than spending the extra cash
How do you like that defuzer you have?
claydo
Mar 3, 2013 07:09 PM
82f3504x4
18
Apr 22, 2008 06:47 PM
Highmark18
Feb 8, 2006 12:40 PM
grbr95
Oil & Lubrication
Aug 7, 2005 07:57 PM
