injector pump
Old Jan 19, 2008 | 09:54 PM
debo89's Avatar
debo89
injection pump
I have a 1993 e-350 7.3 non turbo that is making a very fast ticking sound.The more you push down on the gas the faster the ticking gets, is the injector pump going out? How long does it take to change a injector pump out?
Old Jan 19, 2008 | 10:00 PM
Tenn01PSD350's Avatar
Tenn01PSD350
We don't know debo. You are on the wrong forum but welcome to FTE. A mod should move this soon or you can post it in the right one.
Old Jan 19, 2008 | 10:12 PM
debo89's Avatar
debo89
injector pupm
I have a 1993 e-350 7.3 non turbo, Iam getting a ticking sound that gets faster the more gas that I give it the faster the ticking gets, and I am getiing fuel on the top of the motor. Is the injection pump going out?thanks
Old Jan 19, 2008 | 10:18 PM
Franklin2's Avatar
Franklin2
You are going to have to find the source of the leak. No quick solution to that one. especially since you have a van.
Old Jan 19, 2008 | 10:50 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Fuel could be leaking return lines, are you having a bad time starting it?
Could be a leaking injection pump, that will be fun to try and see on an E series.
Could be a leaking fuel filter.
And finally one of the fuel lines may be leaking, either the injection lines or the fuel supply lines.
I merged both of your threads together.
Old Jan 19, 2008 | 11:52 PM
ryaneverk2's Avatar
ryaneverk2
Welcome to FTE, debo89!
Thread moved to 7.3L IDI section... you should get some great help here.
