Here is a Earnesteugene type post minus the math as I must have thrown out the formula/worksheet from this crap pile I call my workstation.
Anyway, while considering turbos I took the liberty of using the calculators on the Garrett site to plug some desired HP #s into units I was considering that had an efficiency map available.
This is using the displacement of the 7.3 with a stock IC (2psi drop) and factor of 1 psi for air restriction. As you can see the H2E has a huge potential for power but without a BB center so must make it lower. Not sure how high it can survive but it appears to be loafing at 500hp in our application.
This is just food for thought and you can see where I erred on my initial calculations on the GTP plot. If they don't line up, your math is wrong. Draw a line for your desired HP level.
Well before this fades away into oblivion, I just wanted to say why I posted this. If you are considering a turbo upgrade, you really ought to do the math to know what you are buying. Any model that does not provide a efficiency map will leave you guessing. Yes, I know there is the tried and true WW and/or the ATS but if you are ready to spend 4 digit cash, do your homework.
That is all. To infinity and beyond, and on to oblivion.
They were flow tested. Not surprisingly the #4 tested lowest on the sheet. Almost seems like bad Orings the way it smokes but does not explain the buzz test.
Wow a bad injector, couldn't swamps find that out from the shop before they even sent them out if they were bench tested?
BTW, why is that lame? It is not totally dead, just not up to par. It may be from something I did, who knows? Bottom line is they want to fix it at my earliest opportunty at no cost and they are going to pull it. Does it get any better? I think not, and that is far from lame. Way far from lame. Good people as far as I am concerned.
Hope you fare better. I just know I will be smokin the tires real soon. Heck, I can smoke em now as it is.
Man - I am not up to speed o n this at all. I'm glad you posted it since I am bouncing back & forth between the GT38R and the H2E. I need to educate myself on turbo maps.......
