Ignition Key Query
Old Jan 19, 2008 | 07:20 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Ignition Key Query
Do any of our fine members here know if a stealership can cut a key for you with no more information than the VIN? It doesn't make sense that they would be able to, simply because of the fact that the number is visable to anyone that cares to look. I am only asking because I want a perfect copy and not a hardware store special.
Old Jan 19, 2008 | 07:32 PM
fxstbchopper's Avatar
fxstbchopper
Last time I had a key made by the dealership they had to have the key to be copied to make the copy.
Old Jan 19, 2008 | 07:33 PM
Markadeck's Avatar
Markadeck
That's kinda what I figured. Thank you for the reply.
Old Jan 19, 2008 | 07:40 PM
farmdad's Avatar
farmdad
If you have the registration or title in your name and with the VIN, they will make you a key from the VIN. May have to be the title only. You also need ID to prove that you are you. Usually a photo drivers license will do.
Old Jan 19, 2008 | 07:49 PM
Markadeck's Avatar
Markadeck
Well that is a little bit better news seeing how as I have all that stuff. Just any stealership can and will?
Old Jan 19, 2008 | 08:54 PM
farmb0y's Avatar
farmb0y
The one I worked at did it that way. Don't know what else you could do to prove ownership.
Edit: The boy was on my computer again. Post was by farmdad.
Old Jan 20, 2008 | 09:13 AM
totin_tools's Avatar
totin_tools
I know when I worked at a few dealers in high school the keys came with a 4 or 5 digit number. If you had that number I know for sure they could cut them.
