460 flywheel???? for engine swap
Old Apr 13, 2002 | 04:59 AM
gray79f250's Avatar
gray79f250
Post 460 flywheel???? for engine swap
im doing the 460 into the 79f250 swap and want to keep my 4speed what flywheels can i use other than the l&l ive been told some others will fit in the 351m bell with some grinding but im unsure would just like some input on what you guys are using the engine is between 73 and 78
Old Apr 15, 2002 | 12:22 AM
LxMan1's Avatar
LxMan1
If I'm not mistaken, the bellhousings are the same for the M series and the 385 series. They are on an automatic.
Old Apr 15, 2002 | 01:10 AM
merc460's Avatar
merc460
Fe 360 or 390 flywheels will work I you do a search on this subject you should get a hit because it has been brought up many times Eric
Old Apr 15, 2002 | 11:24 AM
gray79f250's Avatar
gray79f250
thanks merc i was told the 390 would but the engine would need to be balanced which i didnt think would be right im gonna do a search now i think it should just be a bolt in deal
Old Apr 15, 2002 | 01:14 PM
merc460's Avatar
merc460
The balance for the earlier 460 is the same as the 390 but the later 460 79 and up are balanced diferently Eric
Old Apr 16, 2002 | 01:21 AM
proford460's Avatar
proford460
Red Mercury
Engine Swaps
Oct 24, 2024 08:03 AM
jbrown9709
17
Oct 7, 2022 08:46 AM
Fordman7992
Feb 3, 2016 08:22 AM
mightymoose95
Jan 24, 2016 07:45 PM
mightymoose95
Jan 24, 2016 01:32 PM
