Gauges
Old Jan 19, 2008 | 05:01 PM
Mr. G's Avatar
Mr. G
Gauges
So I have been trying to make my gauges work on my 74 F250. Just out of curiosity I put a test light on the left/hot side of the inst gauge fuse in the fuse block and it is dead. I also have a large black with green stripe wire protruding out of the top of the fuse block that is cut off. Does anyone have a diagram for this?
Old Jan 19, 2008 | 06:39 PM
Mil1ion's Avatar
Mil1ion
The Gauges work off a 5v pulsing power to ground signal.
The ICVR controls that pulsing power and everything is done through the 18 pin connectors on the back.
Check the back of the fuse box for corrosion.
I'll check for an illustration
Old Jan 19, 2008 | 07:14 PM
Mr. G's Avatar
Mr. G
Thanks for the reply. I did replace the ICVR. What is weird is that the fuse block has some dead spots. I did remove the exposed wire sticking out of the top of the block. This whole thing started because I was trying to make my fuel gauge work but it has occured to me that since this truck has an aftermarked fuel tank, maybe they didn't bother hooking up the gauge. I have seen worse on this truck.
gnwalker
Electrical Systems/Wiring
Jan 28, 2014 11:49 AM
enrico
Jan 22, 2014 05:09 PM
blampe1
2004 - 2008 F150
Jun 23, 2012 10:00 AM
loleuiha
Feb 15, 2012 10:20 AM
Dr2006
Jun 11, 2009 11:47 PM
