heater core
Old Jan 19, 2008 | 01:24 PM
HENDEL's Avatar
HENDEL
Post heater core
my 90 ford e-150 302 5.0 van
feel warm like does not burn you out
i took it a part i noticed there was no type core seal in it
would that explain warm heat or is there suposued to be
a seal around the core when i changed the core 1 year ago
i noticed a ruber like gasket around core i should had took it off
but i did not
Old Jan 19, 2008 | 06:18 PM
Keepin It Real's Avatar
Keepin It Real
Yes, there should be rubber/foam seal around the core so the air from the fan has to go thru the core and not around it. You can easily fab up a good seal using that foam water pipe insulation from the hardware store. Use adhesive to attach the stuff to the core.
Norton72
Nov 18, 2014 09:28 AM
4x4 Bart
44
Mar 7, 2014 12:39 PM
jgavac
Nov 23, 2012 11:06 PM
chappys4life
15
Dec 28, 2009 06:27 PM
honeyCANdew
Jun 19, 2006 11:22 AM
