Sponsored by: Auxito
headlights blow fuse
Old Jan 18, 2008 | 04:04 PM
wilburn's Avatar
wilburn
Cool headlights blow fuse
My automatic headlight fuse blows every time they cut off. They will come on, but when the light sensor tries to turn them off, the fuse blows. Is there a relay? If so, Where is it? Anyone know?? Could the light sensor switch cause this?? I changed the main headlight switch, and it did not solve the problem.
I'm about to blow my own fuse over this!! HELP!!!!!
Old Jan 18, 2008 | 07:09 PM
projectSHO89's Avatar
projectSHO89
You need to identify what year your truck is in your post....
Old Jan 18, 2008 | 09:45 PM
wilburn's Avatar
wilburn
SORRY!! My truck is a 2002 f150 super crew 5.4 engine.
Old Jan 19, 2008 | 07:03 AM
projectSHO89
Which fuse, specifically? There are five fuses in some way involved with the autolamp system, more if your truck has DRL.
Does it matter if the MFS has low or high beam selected?
Have you had any unusual activity with the O/D light on the transmission selector. Has there been any correlation with moving the lever and the fuse blowing?
Steve
Old Jan 19, 2008 | 07:40 AM
wilburn's Avatar
wilburn
The only fuse that blows is #29, which is the autolamp module, transmission overdrive control switch, central security module, beltminder fuse. It also is the fuse for the automatic door locks, but I disengaged them as per the owners manual. When I replace the fuse, the lights come on automatically as I am sitting in the dark carport, but when I back out and light reaches the dash sensor (or something else), the fuse blows.
Old Jan 19, 2008 | 05:19 PM
projectSHO89
...and the rest of the questions.....
Old Jan 21, 2008 | 07:52 AM
wilburn's Avatar
wilburn
There is no overdrive light activity. The lights work on high beam and on low beam. I tried them again this morning and they blow the fuse as soon as light hits the sensor in the dash that turns off the lights. I used a flashlight on the sensor as it sat in the carport. Am I right in assuming that that light sensor switch is shorted?
Old Jan 21, 2008 | 08:24 AM
projectSHO89
Probably. I don't see anything else in the circuit that would make any sense.
Steve
