Fuel pump supply (or lack off) problem
Old 04-29-2002, 06:04 PM
bearhugs28's Avatar
bearhugs28
bearhugs28 is offline
I've got an '83 F250 with the 460 engine and an automatic transmission, I just replaced the headgaskets etc. Now i've put everything back together and it won't run. The problem is that it runs when i poor some gas straight into the carburator but then it stalls cause it runs out of gas. I disconnected the fuel supply line to the carburator and had someone cranck the engine but nothing comes out, i checked the inerta switch wich works. Anyone has some ideas what i can do or test ? Suggestions wellcome.
Thanks, Aalbert.
Old 05-05-2002, 01:28 PM
trinogt's Avatar
trinogt
trinogt is offline
My truck had this problem. It was solved by removing the fuel pump, bolting on a delete plate, and installing an electric pump.
Mark
Old 05-05-2002, 04:57 PM
Ford79's Avatar
Ford79
Ford79 is offline
One cause could be that you forgot to install the fuel pump eccentric on the front of the cam(if you replaced the timing chain). Another could be that the fuel pump is bad. Third could be the fuel line is bad, filter plugged or a loose hose clamp on a rubber to steel fuel line connection.
Old 05-06-2002, 02:14 AM
Superdave's Avatar
Superdave
Superdave is offline
bearhugs28, What was the etc? Did you get into the timing chain and gears? Did you remove the fuel pump from the timing cover?
Old 05-06-2002, 09:07 AM
DeGideo's Avatar
DeGideo
DeGideo is offline
