Intake manifold gasket help
Old Jan 17, 2008 | 09:08 PM
pitbulls20's Avatar
pitbulls20
I have a 78 f250 and I bought a intake manifold gasket kit and it was just the aluminum pan 2 rubber gaskets and some sealant in a small tube. It was a Fel-Pro brand set and I am wondering if there is supposed to be some kind of actual gasket material to go between the heads and manifold. The set I have now would put the aluminum looking pan between the metal with nothing else. Is this the way it is supposed to be and just use the sealant or isn't there supposed to be and actual gasket? Did they give me the wrong thing because it cost me $35. Thanks
Old Jan 17, 2008 | 09:37 PM
73f100shortbed's Avatar
73f100shortbed
You can make a thick bead with the rtv. Let it set up a bit before putting the intake down though. You do not want a big glop of rtv falling down into the motor. Some gasket sets have an actual gasket as in the case when I did the gaskets on my 302, yet when I did intake gaskets on a 96 Bronco 302 the other day it was just rtv.
