Code P0506
Old Jan 17, 2008 | 08:09 PM
F150CUSTOM007's Avatar
F150CUSTOM007
Unhappy Code P0506
Hi My Neme Is David And Need Help. Look I Put A S&b Air Intake After That The Gauge Showme Check Engine And When I Check Whit Scanner Show P0506 And When The Truck Is Running Is Turn Off You Know Sonthing About This
Old Jan 17, 2008 | 09:20 PM
DaMole's Avatar
DaMole
When you installed the intake did you unhook the battery and hook it back up after the install? If not, you need to unhook the battery for about 5 minutes then hook it back up. This will reset the computer and allow it to relearn the different air flow.
Ace!
Jun 26, 2017 05:19 AM
Kyle Campbell
May 30, 2017 12:05 AM
BirchyBoy
Jun 23, 2016 12:04 PM
JerryLewis
Feb 19, 2016 06:09 AM
Autoarcheologist
Sep 9, 2015 12:01 AM
