Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Wind Chill Warning
Old Jan 18, 2008 | 09:35 PM
96sherm's Avatar
96sherm
well...the screw is perking just fine... plugged in and a lengthy warm up makes her feel groovy. co-tradesmen's chebbies were announcing their piston slap loud and clear!!
Old Jan 18, 2008 | 11:34 PM
preppypyro's Avatar
preppypyro
Speaking of piston slap, you shoulda heard this 6 liter ford start up at the hotel this morning. My god it sounded terrible, and he was plugged in. Something must have been up there.
Old Jan 18, 2008 | 11:37 PM
Fomoko1's Avatar
Fomoko1
Maybe some one swapped in a cumming in it.....
Old Jan 18, 2008 | 11:40 PM
LaredoF350's Avatar
LaredoF350
It depends which 'flash' they have. There are a couple that have addressed the rough run on start up. One involved the injectors 'buzzing' so to speak after shut down to remove the excessive oil and the other involved an inductive type of heat strategy. Both make a huge difference in that run quality on cold starts. Of course, oil viscosity still is a variable.
Snowking's Avatar
Snowking
Those 6.0's don't sound good cold. Of the 3 Petrocare has the newwest one defiently sounds the worst cold weather starting, but once they warm up they're fine.
Old Jan 18, 2008 | 11:42 PM
preppypyro's Avatar
preppypyro
Lol never know!
Had a weird color scheme ive never seen before either dark blue with a greenish blue stripe on the very bottom.
Old Jan 18, 2008 | 11:43 PM
preppypyro's Avatar
preppypyro
Laredo, do you keep yours in a heated shop, or just plug it in? How does yours sound when it starts?
Old Jan 19, 2008 | 06:13 AM
96sherm's Avatar
96sherm
wish i could have listened to a 6.0 rattling in the morning... some day...
Old Jan 19, 2008 | 08:23 AM
preppypyro's Avatar
preppypyro
Just go to the holiday inn convention center in edmonton, there is always diesels of every make and model rattling away in the morning!
Old Jan 19, 2008 | 10:37 AM
LaredoF350's Avatar
LaredoF350
Always in a heated shop. The truck will idle up to about 1000 rpm when its cold then drop back to low idle. I did that high idle mod that revs it up to 1200 and keeps it there - much better when really crunchy out. I run 0/40 synthetic for the winter and it will rattle some but it will do a bit of a chugging when its cold started but not bad. Mine has the latest flash where it used some type of inductive heat strategy to preheat the injectors and it makes a difference. It doesnt have quite as much of that 'knuka - nuka - nuka' sound of a 7.3 but like I said, it kind of dos a few 'chugs' till things level out. I think this engine uses sensors to adjust timing, fuel delivery, etc as well as some other parameters and it takes a few seconds of running and oil flow for it to decide where it should have things set.
Old Jan 19, 2008 | 01:31 PM
Secret Agent 069's Avatar
Secret Agent 069
For you all in All points frozen.... Have you ever seen/used a heater like this??
we dont get much below zero down here, but I'm thinking of another use for it...
http://www.jcwhitney.com/autoparts/P...001484/c-10614
Old Jan 19, 2008 | 02:03 PM
Fomoko1's Avatar
Fomoko1
These are quite common especially for truck, farm and construction equipment diesel engines. They work well as long as the heater is at or below the coolant level.
Old Jan 19, 2008 | 02:07 PM
  #28
Secret Agent 069
I'm thinking of hooking the 1000 watt upto a genset, and taking it camping. Attach the ends to a garden hose, and make a "camp fire" hot tub.
Old Jan 19, 2008 | 03:45 PM
  #29
Fomoko1's Avatar
Fomoko1
It maybe too small for that, I think it`ll take too long to get all the water up to temp if it ever does. It all depends on the outside temperature and the size of your hot tub.
Old Jan 19, 2008 | 08:17 PM
  #30
preppypyro's Avatar
preppypyro
Yeah that would be too small. Maybe a few of them at once might work.
