does yours leak? pic
Old Jan 17, 2008 | 06:16 PM
Benny2002's Avatar
Benny2002
Exclamation does yours leak? pic
Back side of the hydro booster as it comes through the firewall and connects to the brake pedal assembly. A tech pointed this out to me today, dont know how long its been doing it but i had moisture on the backside of it and if i push the pedal in and out a very small amount seems to come in and out of the pushrod? Anyone have exp with this? What should i do? Thx<center>
<img src="http://i71.photobucket.com/albums/i149/bensbucket_2006/080117_172132.jpg" alt="Photobucket - Video and Image Hosting"><br><br>
</center>
Old Jan 17, 2008 | 07:18 PM
Benny2002's Avatar
Benny2002
nothin????
Old Jan 17, 2008 | 07:47 PM
JIM ROLAND's Avatar
JIM ROLAND
Just a thought: From the looks of the rust on the bracket, my guess would be condensation inside the truck. Interiors of vehicles will show condensation on the inside of the windshield etc., especially this time of year. It can be caused by moisture from your shoes, maybe a little moisture trapped under a floor mat etc. I would suggest leaving the windows open and try to get rid of the moisture if possible. I sell autos for a living and I've seen a lot of them create condensation on parts inside of them, (i.e. cold metal parts), especially in cold weather and/or after being cleaned inside. Just my 2 cents. Good luck and let us know what the fix is!
Old Jan 17, 2008 | 08:00 PM
Kwikkordead's Avatar
Kwikkordead
What kind of liquid is dripping off of the plunger there?
If it's red, then you need to replace the booster assembly. Ouch. $$$$$
Old Jan 17, 2008 | 08:09 PM
mueckster's Avatar
mueckster
Mine has a small amount of P/S fluid in the same general area, but does not leak out or gotten worse. I consider it to be normal, until it starts dripping on the firewall or floorboard.
Old Jan 17, 2008 | 08:11 PM
yellow401's Avatar
yellow401
Yeah, mine is the same as yours. I have noticed that before on my booster. It is definetly "wet" on the inside of the truck around the piston. Not sure if it is a problem or not? I am curious also. Mine also has the rust. At least your not alone...
On a side note, my GMC has rust on the gas pedal and brake pedal, and I'm sure it is from soaking wet boots, wet/snowy floor mats, salt etc. Not unusual for that to happen.
Old Jan 17, 2008 | 08:14 PM
JIM ROLAND's Avatar
JIM ROLAND
When he said moisture I assumed water; he could of meant fluid. Oops.
Old Jan 17, 2008 | 09:27 PM
Benny2002's Avatar
Benny2002
Ya its red, i wiped it all down, before the pic probably shouldnt have for comparison but ya it was moist all over it, nothing dripping down the firewall inside or out, when you push the pedal in and out it looks like a small amount comes out and then goes back in when you release it or vice versa. I hope it doesnt have to be replaced, anyone know if its the whole thing or can the snap ring be popped and the rear taken off and replaced?
Old Jan 17, 2008 | 10:44 PM
JIM ROLAND's Avatar
JIM ROLAND
A while back, I posted about mine having a "rubber to rubber" type squeak. Some others here had the same problem. I had to spray it with wd-40 and finally it stopped. Maybe a small amount can be a good thing! Check out the thread: https://www.ford-trucks.com/forums/6...ed-advice.html.
In my opinion, I wouldn't be upset until there is real reason to be! Just my 2 cents worth. Good luck!
Old Jan 17, 2008 | 11:18 PM
670johndeere's Avatar
670johndeere
I believe it is a complete replacement. I had to replace mine a couple of years ago, mine developed a leak on the engine compartment side. Just over $200.
Old Jan 18, 2008 | 09:01 AM
Kwikkordead
If it's red, then it is ATF from the hydraulic system. Sooner or later it will begin to leak enough to get on your shoes.
Old Jan 18, 2008 | 10:58 AM
HKusp's Avatar
HKusp
Well $200 dollars for the assembly, I hope the shoes he's wearing aren't too expensive.
Old Jan 21, 2008 | 11:41 AM
Rock Auto Justin's Avatar
Rock Auto Justin
Former Vendor
If you do need to replace it, we can get you a pretty good deal on a reman unit:
http://www.rockauto.com/catalog/x,ca...,parttype,1884
Thanks for looking,
Justin
Old Jan 21, 2008 | 04:11 PM
Benny2002's Avatar
Benny2002
I have a hydro booster that seems to be for a vacuum system am i missing something? Thanks for the help.
Old Jan 21, 2008 | 04:58 PM
Benny2002's Avatar
Benny2002
This part looks a little more my speed, can you tell me for sure if it fits a 2002 7.3L PSD?
A-1 CARDONE Part # 527357 More Info {[Hydro-Boost] Reman.}
w/Hydro-Boost
Ford wants 318 dollars
