Modular V10 (6.8l)
Recalibrate Electronic Throttle control?
Old Jan 17, 2008 | 12:32 PM
MuddyAxles's Avatar
MuddyAxles
This has probably been covered before, but a search has not resulted in what I need to know.
Someone mentioned hesitant throttle response and possible need for recalibration.
Is there a recalibration process for the drive-by-wire V-10's?
Can this be done at home, or is this a shop procedure?
Can a dummy like me do this?
Thanks
Old Jan 17, 2008 | 01:29 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I think they meant a reflash or reload of the "calibration".
I think the TSB for that issue says to reflash the PCM with the latest software, and replace the TPS (pedal sensor) and the throttle body.
Old Jan 18, 2008 | 01:53 AM
SID297's Avatar
SID297
A custom tune can circumvent the factory nanny settings and allow for more crisp throttle responce if that is what you're looking. for.
Old Jan 19, 2008 | 06:17 AM
DirtyDogOfTheDesert's Avatar
DirtyDogOfTheDesert
Yes it can be done at home.
Turn on key.....(do not start)
Slowly press pedal all the way to the floor
Hold for 5 seconds
Slowly release pedal back up
Turn key off.
Repeat as many times as you feel like..... (3)
Throttle position now recalibrated.
the_auto_tech
2009 - 2014 F150
15
May 23, 2016 10:02 AM
bass-n-fire
1997 - 2003 F150
Mar 8, 2016 06:04 PM
Ron94150
Aug 29, 2015 09:23 AM
fusefinder
Nov 28, 2014 06:31 PM
rat49f6
Jun 21, 2012 02:38 PM
