frame swap
Old Jan 17, 2008 | 10:57 AM
BradyCouchman's Avatar
BradyCouchman
frame swap
so i have read about people putting late 70s frames under 69s and 70s boddys. yet i have not really read about someone who DID it and can really say what it really takes do it. i have a 2wheel drive and want 4wheel drive. so i was thinking about getting a 4wheel frame and changeing them out. Can any one really tell me what it will take do it? Thank you.
Old Jan 17, 2008 | 07:48 PM
19704X4F250's Avatar
19704X4F250
Brady, I am in the process of doing what you want to do. I have a 1970 F-250 that I am putting on a 1979 4X4. It is a good swap but time consuming. The cab will bolt right up as the mounting points are the same. I used the 79 steering column and had to splice in the electrical as the plugs are different. I had to run 2 wires to the Duraspark to use it. The alternator wiring was different but not a big problem. The frames are different behind the cab as the 79 gets wider. I haven't put the bed on yet but it shouldn't be a problem to mount. I have heard that there will be a 2-4 inch gap behind the cab as the 79 frame is longer, but I plan on putting a roll bar in that space. Here is a link to go to see what I have done. Dan https://www.ford-trucks.com/forums/6...4x4-frame.html
