Sponsored by: Real Truck
coolant leak
Old Jan 17, 2008 | 09:22 AM
KEO's Avatar
KEO
Unhappy coolant leak
I have a 6 liter that's been setting for about 2 weeks. Went out and noticed coolant on the ground, dripping off the bell housing on the passenger side. Checked the top of the engine and maybe only a drop or 2 on the intake. Does anybody have any ideas where it could be leaking from?
Old Jan 17, 2008 | 09:58 AM
redford's Avatar
redford
FTE Leadership Emeritus
Hi KEO.
Welcome to FTE!
Take a close look at your heater hoses. I'm not a 6.0 PSD guy, but my first guess would be heater hose or heater core leak.
Old Jan 17, 2008 | 10:13 AM
3000 FPS's Avatar
3000 FPS
It is coming from the EGR cooler hose. It is a small hose about two inches long connecting to the egr cooler. If you go to the 6.0L forum and then go to the tech folder there is a link in there for the 6.0L bible. It will show a picture of where it is located. It is a bit of a pain to get to.
Old Jan 17, 2008 | 11:00 AM
skoveng's Avatar
skoveng
Yes, it's the EGR cooler hose. My 6.0 did the same thing about a month ago and has not did it since. Had it to the dealer, they pressure tested it and it wasn't leaking. I'll change it out myself in the spring if I'm not forced to do it sooner. From what I have read, it only seems to do it when it's cold. Good luck!
Old Jan 17, 2008 | 11:10 AM
Kep4's Avatar
Kep4
Jäger
Here's the pic for you: dan.prxy.org/Truck/6L_bible_html/html/Page_074.html
And the EGR cooler: www.forddoctorsdts.com/articles/article-05-01.php
You should inspect the EGR cooler. They have been known to split at the seams if the engine oil cooler gets plugged with block casting sand. Adding a coolant filter to the 6.0 coolant system is very beneficial and will prevent this from happening. Dieselsite has them.
Old Jan 17, 2008 | 11:26 PM
KEO's Avatar
KEO
Thanks I'll check it in the morning. Sounds alot better than what I was thinking!
Old Jan 18, 2008 | 10:03 AM
KEO's Avatar
KEO
Thanks for the help!!! Went out this morning to check,sure enough, exactly what it was. Looks to be a real pain to chainge out!!
Old Jan 18, 2008 | 10:23 AM
skoveng's Avatar
skoveng
If it's still under warranty, let the dealer take care of it. Other wise I saw a post on how to take care of it without removing the turbo. Drain the anti-freeze, cut he hose in half and remove it. To install the new, remove the anti-freeze feed cap from the oil cooler, slide the new hose onto the EGR cooler pipe, re-install the oil cooler feed cap and slide and twist the hose back into place. Refill with anti-freeze. I haven't tried it yet though.
Adrenalin540
Dec 27, 2014 11:47 PM
KRDiesel
Nov 23, 2012 08:56 PM
olbattlebuggy
Feb 14, 2011 02:02 AM
DVS 99
3.8 & 4.2L V6
Dec 8, 2009 11:22 AM
bbtkd
Oct 7, 2001 12:19 PM
