fried voltage reg
Old Jan 16, 2008 | 09:18 PM
todd jo's Avatar
todd jo
fried voltage reg
What could cause a new voltage regulator to go haywire? 2 times in less than a week my reg has fried. After sitting for hours, at a cold start situation. The alt light comes on with the key and stays on after the rig is running? The only thing I had done diferently both times was listen to the radio for about ten minutes with the key in the acc. position before leaving the rig. Is the radio related to the failed regs? I been carrying a spare and I just replace it and all is fine again.
What gives? Todd
Old Jan 17, 2008 | 12:24 PM
BikerDude's Avatar
BikerDude
Make sure you have a good, clean ground on the VR. It could also be something related to your switch vice the radio.
Old Jan 17, 2008 | 11:18 PM
todd jo's Avatar
todd jo
The ground on the core support, the terminal connection, and the back of the Vr itself are good and clean. I sanded the crap out of them to get good clean metal. How could/might the radio interfere? I am considering a re-wire of the radio bypassing the ignition switch altogether.
Todd
Old Jan 18, 2008 | 06:26 PM
jwtimme's Avatar
jwtimme
the only time I have had a VR fail is because some one hooked up the beatery up backwards. caused a short and the battery to drain overnight. took about a week to find the vr at fault.
Old Jan 18, 2008 | 08:10 PM
bigblockford_390's Avatar
bigblockford_390
What kind of voltage regulator do you have, one is a thin type and the other is pretty thick? The thin ones are a solid-state device where the thick one has three contacts in them, much like the points in the distributor. Two screws holds that cover on and you can see what is in there. My old one was a point style and just like the points on your distributor after they make lots of contacts the ends get chewed up and no longer make a good connection. You can try to clean them up with a small file but you might have to replace it.
If you install a new one I would go with the solid state style, no moving parts which improves the reliability.
Jeff
Old Jan 18, 2008 | 08:31 PM
todd jo's Avatar
todd jo
The 2 that fried were solid state units. I chose that over a new points style? I am being careful not to leave the radio on. we will see how the 3rd one goes. It was from a 72 that I pulled the core support at the wrecking yard. Maybe there is a difference between the aftermarket ones and Ford ones.
