Sponsored by: Real Truck
Carrier Bearing Help
Old Jan 15, 2008 | 08:24 PM
Cole26's Avatar
Cole26
Rubber is pretty much torn all around..I have been chasing a vibration and just had new ujoints and the rear shaft retubed..It pretty much gone now but i believe i need to swap out the bearing..Does it need pressed off or on I see that I have to remove that inch something nut just wanted some advice from some one that has done it thanks guys i almost have this thing fixed..i think
Old Jan 15, 2008 | 09:01 PM
Fordfreak_24's Avatar
Fordfreak_24
I went to do mine but got the drive shaft off to realize that they need to be pressed on and off. I know that they can make all sort of vibrations and clunks depending on how bad its worn. Any machine shop or napa for that matter should be able to do it for you fairly cheap. Good luck.
Old Jan 16, 2008 | 01:08 AM
Cole26's Avatar
Cole26
Well thanks for the heads up fordfreak i'll check with napa in the a.m. Seems like it should be made outta poly or somethin..
Old Jan 16, 2008 | 06:17 AM
mtcrss14's Avatar
mtcrss14
now that is what i hear but i got mine off with about two hits with a hammer and the new one slid right on with a couple hits with the hammer and socket.
