alt problem??
Old Jan 15, 2008 | 08:07 PM
cwt580's Avatar
cwt580
alt problem??
hey all its been some time!!!!
well i think its finally happened. started my truck tonight. started fine but batt light is on and alt gauge is reading low. Gauge comes up from about 9 volts to about 11 volts after glow plug relay kicks off.
My question is which one? the top one seems noisy and slight squeal when coming down to idle after quick rev. i hope its this one($150) and not the bottom one($240). no access to tester w/o taking off. How do i check with volt meter? Looks easy enough to change.....
please help. i am supposed to leave for snowmobile trip in 3 days.
2000 f350 7.3 dually stick 4:10 gears 4x4 217,000 miles
Old Jan 15, 2008 | 08:11 PM
F350-6's Avatar
F350-6
Which one? Do you have dual alternators? Autozone was able to check my alt without pulling it from the truck.
I believe if you touch the big wire off the back of the alt. with a multi meter you should see around 14 volts if it's good.
Old Jan 15, 2008 | 08:27 PM
cwt580's Avatar
cwt580
yes duals.....acts like the one that runs GP's battery. is that the top one???
Old Jan 15, 2008 | 08:41 PM
JIM ROLAND's Avatar
JIM ROLAND
Use a multimeter as was previously stated above, red lead to hot terminal on back side of alternator and black lead to a ground somewhere. You can check each alternator independently and find the bad one.
P.S. I'm not as familiar with the schematics of the dual system as some of these guys, but I believe this should give you a very valid result.
Old Jan 15, 2008 | 08:42 PM
F350-6's Avatar
F350-6
Beats me. I've only got one. If you think you have a GP issue I'd start with checking the GP relay to see if it's working properly. If it's an alt issue, then as I said, they can be tested without taking them off the truck.
Old Jan 15, 2008 | 08:46 PM
greedy737's Avatar
greedy737
I think its the top one too!! but I thought they work together to charge both batts.
Old Jan 15, 2008 | 08:47 PM
cwt580's Avatar
cwt580
glows are working fine. because it started at 20 degrees not plugged in. light comes on after it starts before GP's quit running. interior lights are dim until GP's click off. then volt s gauge and lights come up slightly but still not fully. "idiot light" never turns off!!!
Old Jan 15, 2008 | 08:52 PM
F350-6's Avatar
F350-6
Then assuming your batteries are good (I don't think I've ever seen a battery light for bad batteries) then I'd say one or both the alternators are bad. I have no idea which one. I also have no idea if it would be a good idea to replace both at the same time.
Can you check voltage off the back of the alt's?
Maybe someone else with duals will chime in with some knowledge.
Old Jan 15, 2008 | 08:58 PM
greedy737's Avatar
greedy737
Do both batts read the same?? I can't see how the truck would even start, with lights diming etc.!!
Old Jan 15, 2008 | 09:12 PM
cwt580's Avatar
cwt580
starts fine but if the alt is bad its not going to for long. truck runs for a few secs before the light comes on...
Old Jan 15, 2008 | 09:19 PM
F350-6's Avatar
F350-6
My battery light came on when my single alternator started to go. Never had a starting issue because I changed it right away.
Old Jan 15, 2008 | 09:26 PM
spinge's Avatar
spinge
As much as I hate to say this, it might be both alt's. Here is my thinking:
With the truck just running in the driveway after starting, and nothing much running, either alternator would put out more then enough juice to keep everything up to voltage. Just ask all of us with only 1 alt. That being the case (low voltage) would require that both alt's have failed for your voltage to be low. Sorry
Old Jan 15, 2008 | 09:34 PM
cwt580's Avatar
cwt580
what really sucks is....snow and cold and a garage not big enough to pull it in!!!!!!
why would you think both alts at the same?
dash volt meter reads about 11-12 volts when gp's stop. normally about 13-14 volts when running. batt light never shuts off.
just dont see both alts going at the same exact time........top one is making some noise now that ive never heard before tonight. why the difference in price? they must do some different functions or why the need for both?
Old Jan 15, 2008 | 09:40 PM
spinge's Avatar
spinge
Not that both went at the same time, but that one has been dead for a while, and the other just died. Have you ever put an alt on it before? My '00 has had a few, they don't last forever.
Like I said, each alt has the juice to keep the system up to voltage by itself, so it would be really tough to tell just by voltage if one alt failed.
Old Jan 15, 2008 | 09:45 PM
cwt580's Avatar
cwt580
maybe just get away with the one for now. if one had bad windings,brushes,bearings wouldnt that cause a draw on the full system anyway? $400 for alternators is a little hard to swallow.
if only 1 was out would i get any battery light. Maybe both are bad but not this week folks the well is kinda dry right now....
so you say it would probably run on 1? this truck is normally a driveway queen anymore just use for trips and camping....
