alt problem??
Old Jan 15, 2008 | 09:47 PM
cwt580's Avatar
cwt580
got the truck w/ 200,000... i have only done a waterpump so far. only 16,000 miles in 2 1/2 yrs.........
Old Jan 15, 2008 | 09:57 PM
farmdad's Avatar
farmdad
I'm not familiar with the dual alt. setup so just basic diagnostic procedures. I would disconnect the large wire from which ever alt. is easier to get to to prevent back feeding from one to the other. (There is possibly a regulator to prevent this during normal operation.) Start the engine and check the voltage at the large lug on each alt. If there is low voltage from only one, replace that one. If low voltage from both, replace the cheapest one first to see if that gives some charge.
Old Jan 15, 2008 | 10:00 PM
spinge's Avatar
spinge
I guess (but not sure) that you might be able to test one alt at a time by disconnecting it from the system (large battery lead and small plug, sealing each one up well) and then run the truck and see if the voltage does anything.
By the same token (and also not sure on this) you might be able to disconnect the lower in this method, and replace just the upper, and get around for a while.
Just thoughts
EDIT: Beat me to it Farmdad
Old Jan 15, 2008 | 10:05 PM
farmdad's Avatar
farmdad
Rich, good advice about insulating wire ends. Don't need fireworks.
Was the dual alt. setup mainly for ambulances?
Old Jan 15, 2008 | 10:10 PM
spinge's Avatar
spinge
It was standard as part of the Ambo Prep Package, but could be ordered by itself - I think it was for winches and such that are power hungry.
I don't know if there is an isolation device between the two alts so that one won't drain into the other if either goes bad...
Old Jan 15, 2008 | 10:26 PM
cwt580's Avatar
cwt580
to check batteries do i need to disconnect the leads from one of the 2 batts? dont know if they are hooked together. after all the starts and restarts the batts are low. now it wont crank so its time for the charger.......
Old Jan 16, 2008 | 12:46 AM
kb8pgc's Avatar
kb8pgc
You do need to unhook one lead from one of the batteries to check them. Beware of the quick testers for testing them though. Mine both tested good at a local chain part store and after a starter and cable change took them both out for the long test on the machine inside, they both tested bad several hundred dollars after the initial "good" test.
Old Jan 16, 2008 | 01:42 AM
kb8pgc's Avatar
kb8pgc
The service manual for my 99 shows the dual generator option and both alternators are controlled by the PCM on the schematic. If the pcm don't send a voltage to the pin (labeled I in the schematic at alternator), the alternator won't output a voltage so it may have to be taken off to test at the local parts store. Assuming it is telling both to charge may or may not be true. The top one is a 5 minute removal assuming your belt tensioner has the same 3/8" hole to pull it back with a long rachet and easily slide the belt off. Just did mine a week ago. Had a local shop rebuild it for 75$ and back up and running same day. Seems the regulator/rectifier went bad but he also did brushes and bearings. Both alternators have exact schematic layouts so the price difference must be in mounting differences and lack of demand for the second lower unit. The internals appear to be the same for a rebuild if you have a shop that will do it. I'll cross my fingers for you!
Old Jan 16, 2008 | 05:08 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
I'm surprised nobody's pointed out that the alternator's have zilch to do with the running of the gp's beyond keeping the batteries up to snuff so they are capable of doing so.
Old Jan 16, 2008 | 05:42 AM
cwt580's Avatar
cwt580
well the batts are low now. The volt drop is probably caused by this in combination with the alt not charging it. I know the GP's use alot of juice......
Old Jan 16, 2008 | 08:07 PM
cwt580's Avatar
cwt580
tested top alt.....BAD new one installed in 10 min. alls good..
gonna take bottom one off after trip and check out and rebuilt. im assuming its bad too. mechanic said id be fine for now if not forever. as long as im not running a bunch of trailer batteries charging,accessories,welder,etc.......
Old Jan 16, 2008 | 11:33 PM
farmdad's Avatar
farmdad
Glad to hear that you got the problem fixed. What amp rating was the new alternator?
Old Jan 17, 2008 | 01:19 AM
  #28
AustinS's Avatar
AustinS
All you'd have to do to test the bottom one is disconnect the fat positive cable off the top one and read your voltage at the battery if below 13-15V then it would be time for a new one.
If it is bad, it will cause the top one to work more and heat it up. That will cause it to fail prematurely.
I would at least charge your batteries completely with a charger first. The reason so many alt. fail is people think that its the alt job to charge up a deeply discharged battery. It is not. It is to top off the charge of a battery in good condition and to run all the electrical devices in the vehicle. A lot of folks get in a maintanence nightmare between batteries and alt. Bad batts ruin alts and vice versa. With batteries at $100 ea and alt at $200, it adds up fast.
It would be a ten minute job to check it and know for sure. Your call.
Austin
Old Jan 17, 2008 | 05:37 AM
  #29
cwt580's Avatar
cwt580
110 amp BUT lifetime warranty. no one stocks the bottom alt. already had the batteries charged up. new batts last winter.....
