6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
New Truck
Old Jan 16, 2008 | 09:54 AM
Ace!'s Avatar
Ace!
As I was reading down the list of threads I had to re-check what forum I was in. Carbs and plugs...now that's funny. I know it doesn't seem like it would matter much, but if my muffler bearings haven't been torqued down just right I lose 10 - 15mpg right off the get go. Same thing happens when I let the blinker fluid get low.
Old Jan 16, 2008 | 02:05 PM
Alon@ModBargains's Avatar
Alon@ModBargains
Ya, alot of people forget about those muffler bearings, especially with all the new exhaust DPF and everything.. CHECK YOUR MUFFLER BEARINGS!
Old Jan 16, 2008 | 02:14 PM
scottman70's Avatar
scottman70
It's also good to change the air in your tires once a month, and you should change the oil in the gearshift shaft housing that leads to the steering box every 3000 miles. Oh and don't forget to grease your lug-nuts every year!!
Old Jan 16, 2008 | 04:18 PM
richfaa's Avatar
richfaa
And they don't get 30/32MPG .you guys got no sense of humor.
Old Jan 16, 2008 | 04:21 PM
scottman70's Avatar
scottman70
Come on I think we have too much of a sense of humor sometimes!!
Old Jan 16, 2008 | 05:20 PM
pyro2nite's Avatar
pyro2nite
Thats a fine ride. MPG..............WOW. What will happen when it brales in?
I like the blinker fluid check also.
Old Jan 16, 2008 | 07:23 PM
condolan's Avatar
condolan
Well, blinker fluid can run low...but whatever you do: don't let the front and rear light fluid levels go below the minimum! You'll get pulled over.
Those dang muffler bearings...don't last! Not on the new trucks. However, I hear you can squeeze a few more miles out of them if you loosen up the hickey-doo that's tucked in the frame.
Old Jan 16, 2008 | 08:00 PM
griesera's Avatar
griesera
I don't change the air in my tires...i just rotate the air in my tires...i've been having good luck with it. Also with a six speed, if your going 70 mph you can shove it into Reverse and you'll find a hidden 7th gear
Old Jan 16, 2008 | 09:20 PM
versitek's Avatar
versitek
I had a piston return spring go out the other day right through the hood. It is in the shop right now they said that they could put in stronger ones for better mpgs, and more hp and tq. Cant wait!!!!!!
Dave King
Aug 20, 2012 12:24 PM
Grassman09
Ontario Chapter
Feb 8, 2012 09:05 PM
4wydnr
Mar 23, 2009 12:41 PM
kalsc
Mar 11, 2005 09:46 AM
dave thomas
Aug 22, 2001 08:26 AM
