01 Excursion with MPG problem
Old Jan 15, 2008 | 03:28 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Well I never thought I would have to post this question but man. My X acording to the lie o meter is getting 12 MPG shouldnt I be in the 15 to 17 range. I have a 6637 air filter and I got a MBRP 4 inch exhaust on it. Next fill up I will do it hand caluated but the lie o meter cant be that far off can it. Do you guys have any ideas what my problem would be,
Thanks
Nick
Old Jan 15, 2008 | 03:42 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Well Nick, I'm sure you know the normal things to check. Boots, up-pipes, EBPS, EBPS tube. You know the ULSD is giving us heck, and the winter blend also. I had a 2-3 mpg drop in the last few months. Many people are complaining about this very thing.
I think you are amoung the mass.
Old Jan 15, 2008 | 05:26 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Yes to the lie-o-meter. They are next to worthless other than being kind of fun to look at. Being in California the winter should not affect you. But I know when I am in Buffalo or Alaska in cold weather my mpg drops dramatically. Try the recommended dose of DK and see if it is cost effective in improving the mpg. Not to mention the help it is in staving off the damage the ULSD is doing to all of us.
Old Jan 15, 2008 | 05:33 PM
Smokin''s Avatar
Smokin'
Smokin
calculate your numbers manually. Actual miles to actual gallons used.
Old Jan 15, 2008 | 05:39 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Its not accurate at all. Mine sometimes reads 17-20 and i know i'm not getting much over 10, it's just the fact i use alot of fuel while i'm either in park, or in gear but not moving.
weekendwarriorfsw32
Master of Strokes
I am guessing Dk means diesel klean. I f where if the best place to buy it
Old Jan 15, 2008 | 05:41 PM
Markadeck's Avatar
Markadeck
Accurate guess, and I use Wally World, if there is a cheaper place maybe someone will post it for us.
Old Jan 15, 2008 | 05:49 PM
greedy737's Avatar
greedy737
I wish there was a wally world around here!! in PA....
Old Jan 15, 2008 | 06:11 PM
jdecker88's Avatar
jdecker88
No wally world? I have 6 within 50 miles lol. I get about 14 in the winter but the winter blend fuel really shouldn't effect you Nick.
Old Jan 15, 2008 | 06:25 PM
jhand124's Avatar
jhand124
Thanks
Nick
Do you find it odd that his lie-o-meter is reading lower, I have only seen a higher reading....on second thought the truck isn't chiped or have a tuner, so the lie-o-meter might be closer to correct. As far a fuel suppliments go try opti-lube
It was first in the study on lubricity, next to 2% biodiesel DK didn't fair to well, if you put any stock in those studies.
Check at the pump and see if they are adding 2% bio to the ULSD, or switch to biodiesel if you can find it. We don't have it here to cold I think. We do have the 2% soy added to the fuel at Kwik Trip (Located in MN, IA and WI they might be other places)
Old Jan 15, 2008 | 06:29 PM
Markadeck's Avatar
Markadeck
The lie-o-meter is notorious for reading high, so if his is reading 12 I just automatically assumed that his actual milage may just be 8 or 9. Which may be the worse mpg I have ever seen for a 7.3 without towing one hell of a heavy load.
Old Jan 15, 2008 | 06:58 PM
whjco's Avatar
whjco
Wink
6 Wally Worlds within 50 miles but you get 14 of them in the winter? Where do the other 8 Wally Worlds go in the summer?
Inquiring minds want to know . . . . .
Old Jan 15, 2008 | 07:06 PM
jdecker88's Avatar
jdecker88
Winter months more people go to them so they need more but they still just have 5 lanes open . Let me correct my self, I get about 13-14 MPG in the winter.
weekendwarriorfsw32
Master of Strokes
What about changing the fuel filter would that help.
Old Jan 15, 2008 | 07:07 PM
jhand124's Avatar
jhand124
It can't hurt, when was it changed last?
