Engine + Frame = ?
Old Jun 15, 2002 | 10:41 AM
78bigunns's Avatar
78bigunns
Engine + Frame = ?
Old Jun 17, 2002 | 01:03 AM
78bigblock's Avatar
78bigblock
Engine + Frame = ?
I have a 429 that really twists the engine mounts on my 78 shortbox and had a question. If i chain my drivers side head at the front to my frame, will i need to use frame connectors or make my stock frame any stronger or can i just do it and not worry about it bending? hp and torque is unknown but guessing is about 400 rpm= 370 hp & 420 lb/ftof torque???!!!
thanc 4 any help
Old Jun 17, 2002 | 01:05 AM
78bigblock's Avatar
78bigblock
Engine + Frame = ?
sorry bout that, i wish it was 400 ,but its 4000 as you probably figured out
Old Jun 17, 2002 | 07:20 PM
tellico racing's Avatar
tellico racing
Engine + Frame = ?
I run a 429 in my mud truck,it rips the rubber from the motor mount plates as soon as you get on it.I chained the engine 5 years ago and havent had a problem with it bending the frame.I am running 5:13 gears and 40" tires.
Old Jun 17, 2002 | 09:17 PM
gray79f250's Avatar
gray79f250
Engine + Frame = ?
I have advance adapters mounts and they tell you to use limiting straps.
Old Jun 18, 2002 | 08:19 AM
georgedavila's Avatar
georgedavila
Engine + Frame = ?
I've been running modified 460s in an '82 Bronco for many years and stopped breaking motor mounts when I started using mounts from L&L.
http://www.landlproducts.com/
Old Jun 18, 2002 | 09:37 AM
laptopgeek's Avatar
laptopgeek
Engine + Frame = ?
Sounds a lot like my old 57 Cheby Tudor that I had plopped a built-to-the-gills L-88 into. 5:13 rear end, Muncie close ratio 12:1 compression.....etc etc etc -- used to have fun popping the clutch and making it jump coke bottles....
I used a chain to lock down the engine to the frame - never had a problem...
