93 4.9 injector question
Old Jan 15, 2008 | 10:51 AM
tpolley's Avatar
tpolley
what would be the symptom of a faulty injector or injectors on a 1993 4.9 I6. it cuts out real bad under 45mph but seems to run fine at highway speeds or atleast it's not noticable. i've checked fuel pressure and it never fluctuated while the symptoms occured. also it idles fine. i've also replaced the fuel filter. with no change.
Old Jan 15, 2008 | 10:56 AM
quicklook2's Avatar
quicklook2
check codes.
read plugs.
check air filter.
simple things first.
