Question about chain link fencing
Old Jan 15, 2008 | 10:33 AM
ghunt's Avatar
ghunt
Whenever chain link fencing gets "dents" in it from someone/something leaning against it or hitting it, is that fixable?
Old Jan 15, 2008 | 11:34 AM
Nitramjr's Avatar
Nitramjr
If you have some spare fence fabric you could unweave the bent links and weave in some new links. If the fabric isn't too tight you can sometimes do it without unclipping the rest of the fabric. Or you could restretch it afterward.
It's a very easy job.
Old Jan 15, 2008 | 12:04 PM
tewferford's Avatar
tewferford
Just what Nitramjr said, If it is larger than a few links, you can splice in a small section.
Every link is either a left or right hand twist. So in order for repair.
Two links must be removed. One you will use, and the other gets dicarded.
Old Jan 15, 2008 | 01:30 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Lean on the other side to ballance it out
Old Jan 16, 2008 | 12:04 AM
hotroddually's Avatar
hotroddually
i like your thinkin' (if it aint broken,don't fix it)
